VWDiesel Blog
Facebook Group
VWD on Twitter
Fuel Line Length - 068130309
Topic: Fuel Line Length - 068130309 (Read 2600 times)
March 06, 2020, 07:19:46 am
Baxter
March 06, 2020, 07:19:46 am »
Hi.
Long time no see!
Not been here for a long while, since I was last here I started another webshop selling fuel lines etc.
Aaaaannnnyway, I have a customer request for 068 130 309 which is the MKI Golf & Co. feed pipe from the filter head to the injection pump.
I have the components in stock but I don't have the cut length and neither does the customer.
Anyone got one kicking around that they could measure up for me?
FYI, the tube is here.
https://www.cohpro.com/polyamide-tube-fittings/tube/polyamide/polyamide-tube-6mm-id-8mm-od-natural.html
Fitting #1
https://www.cohpro.com/polyamide-tube-fittings/fittings-for-pa-tube/banjo-fitting-for-pa-tube-form-b/banjo-fitting-for-pa-tube-id-4mm-10mm-bolt.html
Fitting #2
https://www.cohpro.com/polyamide-tube-fittings/fittings-for-pa-tube/banjo-fitting-for-pa-tube-form-b/banjo-fitting-for-pa-tube-id-8mm-14mm-bolt.html
March 06, 2020, 09:47:54 pm
Re: Fuel Line Length - 068130309
March 06, 2020, 09:47:54 pm »
2ft filter to pump.
I like tygothane fuel line.
https://www.mcmaster.com/versilon-c-210-a-tubing
Libby suggested it and it's been working great.
Very clear and very flexible.
Tornado red, '91 Golf 4 door,
March 09, 2020, 10:28:29 pm
matrick
Newbie
March 09, 2020, 10:28:29 pm »
Looks like those all say they're for use with air and explains that it shouldn't be used for water or in humid environments because they're ester based. Did you actually use them and they're fine?
March 09, 2020, 10:41:17 pm
March 09, 2020, 10:41:17 pm »
Yeah, I've been using the Tygon hose for all my fuel lines for more than a decade now. I know several other people who have as well. The Tygon works extremely well.
March 10, 2020, 05:05:25 am
Baxter
March 10, 2020, 05:05:25 am »
Thanks for your help, I'll make one at 600mm and see if it works for him.
Many thanks.
March 22, 2020, 06:23:24 pm
sgnimj96
March 22, 2020, 06:23:24 pm »
other part number for the whole thing
13754014256
81 Scirocco 1.6D (conversion) 86 Gofl 1.6D 2003 Golf Tdi 1985 300TD
