Author Topic: adjusting idle on 1.9 TD?  (Read 2640 times)
August 10, 2006, 09:12:46 am
1.9blues
« on: August 10, 2006, 09:12:46 am »
anyone know how to adjust idle on a 1.9td??? i know that the 1.6 have an idle screw - what about the 1.9???
thanks
Reply #1August 10, 2006, 10:47:44 am
Tusker
  • 24
« Reply #1 on: August 10, 2006, 10:47:44 am »
The idle on a 1.9td is adjusted using the long screw that is almost vertical and sets between the IP and the head.  It is very long and thin with a spring around it.  If that doesn't get you enough, you can adjust the residual fuel which is a horizontal screwthat lays horizontal along the IP body, very close to the idle screw.  The residual fuel adjustment has a 10mm locknut on it.
What ever you do, don't use the smoke screw to adjust the idle.  The smoke screw is close to the residual fuel screw but has a 13mm locknut and a head that takes a 6mm wrench or a screwdriver.  HTH.
86 Samurai with 1.9 TD and Toyota truck running gear.
S-PAutomotive.com
