I think my TD is less powerful than it should be.
Topic: I think my TD is less powerful than it should be. (Read 3420 times)
August 09, 2006, 09:04:07 pm
anarchyx34
August 09, 2006, 09:04:07 pm »
I've been driving around my recently swapped in 1.6td for a few days now, and I'm thinking it's supposed to be faster than it is. So rather than guessing I pulled out my g-tech pro, found a flat road, and gave it hell. My 0-60 is 19.34 seconds. Wow... My friend used to have a '79 rabbit diesel 4spd and he thinks something's wrong as well. "Man even my rabbit was quicker than this!" he said.
One thing I've noticed with this motor is that it never smokes. No matter if I floor it, lug it or rev it. I never see any smoke at all come out. I think that's a little abnormal. So i tried pulling the hose off the LDA to see if there was any difference. There was, but not much.
Any ideas where to start diagnosing? I dont have a boost gauge but I definitely can hear it spoolng up, i think my problem is fueling related.
August 09, 2006, 10:03:09 pm
sethyboy85
August 09, 2006, 10:03:09 pm »
thats around stock 18-19 seconds to 60... maybe 17 at the quickest in totally stock form.
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
August 09, 2006, 10:38:52 pm
zagarus
August 09, 2006, 10:38:52 pm »
my 0-60mph was just over 13 seconds, and all i have done was K&N filter in stock box and slightly up'ed fuel.
August 10, 2006, 12:44:00 am
Benjamin
August 10, 2006, 12:44:00 am »
My fiat did+-12,5sec (Gtech and also factory numbers), topspeed: 170. 71hp@4800 128Nm@2500
weight about 850-900kg / 1870-1980lb
everything was stock, it got a T2 wich is laggy an got a IC.
Greetz, Benjamin
Must make +250hp
August 10, 2006, 08:09:19 am
August 10, 2006, 08:09:19 am »
my old na diesel could do 0-60 in around 20 seconds
August 10, 2006, 10:05:10 am
veeman
August 10, 2006, 10:05:10 am »
Air filter and fuel filter are new or at least known good, right? Good quality fuel (not sitting around or old)?
Are you getting full throttle actuation on the pump? Have a friend push the pedal to the floor and see if you can go to the pump and actuate the lever any more. My caddy did that and if felt very sluggish...
Do you know if anyone played with the pump before you got it? Perhaps they turned down the fuel / max speed screws...
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
August 10, 2006, 11:11:11 am
anarchyx34
August 10, 2006, 11:11:11 am »
Air filter and fuel filter are new, and I just filled up the tank the other day.
I'm pretty sure the throttle is opening all the way. I'll try and install a boost gauge and see what happens. I dont know the history of the motor since I got it from a junkyard, but the metal collar on the fuel screw is still there.
August 10, 2006, 08:46:26 pm
anarchyx34
August 10, 2006, 08:46:26 pm »
Ok, hooked a boost gauge up and I am getting 9-10 psi. Should I start blindly turning screws?
August 10, 2006, 09:46:30 pm
zagarus
August 10, 2006, 09:46:30 pm »
(insert lecture on getting an EGT gauge prior to making fueling adjustments).
Andrew
Ooops, guess i missed that lecture time. :lol:
August 11, 2006, 06:05:53 am
shwartzbewithyou
August 11, 2006, 06:05:53 am »
Any difference with the cold start pulled out?
I was going to say to check the collar around the BOV because my BOV was sitting really loose due to a rusted and broken collar. Oddly enough I didn't notice for quite a while.
I would say to start with the pump. If their's no smoke then something has been adjusted. Maybe not the max fuel screw, but something.
Did you try the throttle lever to see if thier's anything more to give? How much travel does the pedal take before the RPM's start increasing from idle?
