Author Topic: Starting trouble when warm.  (Read 4593 times)
August 08, 2006, 10:18:03 am
TomB
  • 88
« on: August 08, 2006, 10:18:03 am »
My Golf starts first time from cold (albeit a little lumpy as I know a couple of the glow plugs need changing), but having been stood for an hour or so, it is subsequently very reluctant to start.
The glowplug light doesn't come on at all, and you have to crank it for about 10 secs before it finally fires up in a great cloud of unburnt fuel.
Initially I'm thinking that the temp sensor may be to blame, but if anyone has any other suggestions, please let me know.
Cheers,
Tom
1.6 Golf GTD - Chip Fat Powered!
Reply #1August 08, 2006, 02:50:48 pm
Doug
chip fat?
« Reply #1 on: August 08, 2006, 02:50:48 pm »
If you are powered by something other than diesel you may need to have the injectors reworked to inject at a higher cylinder pressure so that the oil ignites properly. Ten seconds of cranking would get cylinder pressures and temperatures up. And replace your glows.
Reply #2August 08, 2006, 03:26:04 pm
« Reply #2 on: August 08, 2006, 03:26:04 pm »
You're starter may not be cranking fast enough to ignite the fuel without the glowplugs help. I had this problem until I replaced my starter and grounds.
Reply #3August 08, 2006, 09:09:23 pm
Fisher
  • 148
« Reply #3 on: August 08, 2006, 09:09:23 pm »
Advance the timing a little.
Reply #4August 10, 2006, 01:10:53 pm
« Reply #4 on: August 10, 2006, 01:10:53 pm »
I'm experiencing the same thing.  car starts right up when cold, but takes a few cranks when warm.  must be the fact that when cold the glow plugs come on.
