Author Topic: FS 5 Cylinder NA Diesel Parts  (Read 5167 times)
July 31, 2006, 06:58:23 am
TW
  • 39
« on: July 31, 2006, 06:58:23 am »
Block, recently bored out:  Crankshaft, rod bearings ground to 2nd undersize: 3 (possibly 4) almost new oversive pistons and rings, 5 rods, main and rod bearings (If you want the crankshaft and rods): Oil pump(used for 200,000 miles): Intake and exhaust manifolds:  K&N air filter and air box.  5 good injectors and glow plugs.  Also have cracked cylinder head.  Make me an offer on all or some of these items.  [email protected]  320-260-5298
Reply #1July 31, 2006, 07:25:12 am
addautomotive
« Reply #1 on: July 31, 2006, 07:25:12 am »
Flywheel?
Reply #2July 31, 2006, 09:02:17 am
TW
  • 39
« Reply #2 on: July 31, 2006, 09:02:17 am »
I used the flywheel on the Turbo Diesel
Reply #3July 31, 2006, 12:26:32 pm
itzdshtz
  • 94
« Reply #3 on: July 31, 2006, 12:26:32 pm »
Hi, do you still have the cyl.head and how bad is it ? Herman
1989 Vanagon Westfalia 2.1
1987 Vanagon Syncro Westfalia 2.0 TD
2004 Audi allroad 4.2
1997 Audi A6
1985 Audi 5000 Td
http://vanagonsyncroproject-herman.blogspot.com/
http://picasaweb.google.com/itzdshtz/VanagonSyncroProject02
Reply #4July 31, 2006, 05:00:57 pm
TW
  • 39
« Reply #4 on: July 31, 2006, 05:00:57 pm »
The Cylinder head had a crack that filled the number 5 cylinder with antifreeze.  I never had it checked to see how bad it was.  Most head rebuilders say that these can be welded and be made as good as new or better.  I gave up on this engine after a 2nd head lost the inserts in the swirl chamber and damaged some pistons.
Reply #5August 14, 2006, 03:24:19 pm
Jeremy
  • 6
« Reply #5 on: August 14, 2006, 03:24:19 pm »
emailed you with my more specific questions and requests
Thanks Jeremy
