Author Topic: rebuilt injection pump leaks...  (Read 2837 times)
July 24, 2006, 07:08:42 pm
pleopard
  • 20
« on: July 24, 2006, 07:08:42 pm »
Just one more question/comment from me today:
As mentioned in an earlier thread, I just had the head and injection pump on my 92 1.6TD rebuilt by VW.  Unfortunately, I noticed one of the fuel lines coming from the pump is wet with fuel.  It's not dripping wet, but the nut connecting the line to the pump is darker with a film of diesel.  Should I bother to nag VW about this after the pump was just rebuilt?
I'll post a photo tomorrow if I get around to it.
Reply #1July 24, 2006, 08:41:18 pm
« Reply #1 on: July 24, 2006, 08:41:18 pm »
tighten the nut?
Reply #2July 25, 2006, 07:27:54 am
Master ACiD
  • 328
« Reply #2 on: July 25, 2006, 07:27:54 am »
my rebuilt pump did the same thing. i just gave the nut another 1/8th turn and it stopped.
Reply #3July 25, 2006, 03:54:22 pm
pleopard
  • 20
« Reply #3 on: July 25, 2006, 03:54:22 pm »
That's hilarious!  I feel like such a fool.  I'm a quality control manager for a major hardwood veneer manufacturer and most of my work is fairly theoretical in nature, rather than practical.  Clearly I just gave myself away.  Tightening the nut is the logical solution, but of course I see all the other complexities that may be at play here.  Sometimes, the simplest solution is indeed the answer.  Even if it's not, it's obviously worth eliminating it as a cause before digging deeper.  I should start thinking more like a mechanic, and not a scientist, as I am.
Reply #4July 26, 2006, 07:25:43 am
HP
  • 225
« Reply #4 on: July 26, 2006, 07:25:43 am »
Go tighten that nut!!  :lol:
Reply #5July 26, 2006, 12:56:19 pm
MacGyver
  • 245
« Reply #5 on: July 26, 2006, 12:56:19 pm »
Loose nut is the cause of most automotive problems.
Especially in the driver's seat :P
Reply #6July 27, 2006, 09:39:38 am
Master ACiD
  • 328
« Reply #6 on: July 27, 2006, 09:39:38 am »
if you tignten it a little and it doesnt stop leaking you probably need to use some emry cloth on the line ends and the pump fittings. be sure to clean everything real good afterwards though.
