Author Topic: Intercooler Location/Mounting  (Read 2237 times)
July 20, 2006, 05:04:26 pm
klr650@
  • 52
« on: July 20, 2006, 05:04:26 pm »
Hey everyone. I've asked this question on the Suzuki diesel forum, but I can't seem to get a good answer. Probably because they're mostly Suzuki drivers and not VW guys.
Anyway, I've installed a VW 1.6L TD into a Suzuki Sidekick. I have a Blackstone intercooler from a Saab I'd like to install. I have 2 possible locations.
1. Located where the old air box was. Essentially its right over the driver's side wheel well. Good - straight line to the turbo/intake for hoses. Bad - no air flow for cooling.
2. Below the big 27" VW radiator on the front grill. Good - plenty of air cooling. Bad - a few twists in the hosing to get to the turbo/intake.
So... does the intercooler need air flow to cool properly? Will the twists effect cooling? Which do you think is the best location?
I have pics but I don't have a host to post them.
Thanks, Dave
1993 Suzuki Sidekick w/ 1.9TD
Reply #1July 20, 2006, 05:35:26 pm
MaxHedrm
  • 114
    • blog
« Reply #1 on: July 20, 2006, 05:35:26 pm »
I would lean toward the best airflow you can get through the IC. As long as you make the bends smooth in the hoses & piping their impact should be pretty minor. On the other hand, an IC won't be able to do its job without cooler air flowing across it.
DRIVE: 2010 Golf TDI
DRIVE (less): 2001 TT Roadster
