Author Topic: More inline 6 videos  (Read 6890 times)
July 19, 2006, 12:45:11 pm
2383 GTD
« on: July 19, 2006, 12:45:11 pm »
I found a bunch more videos, and this time they are with a Holset HX40.  The digicam was a bit hard to hold while shifting gears and steering  :shock:  which explains the unsteady recording.
http://media.putfile.com/241-88
http://media.putfile.com/243-74
http://media.putfile.com/244-13
http://media.putfile.com/245-67
Reply #1July 19, 2006, 01:33:31 pm
« Reply #1 on: July 19, 2006, 01:33:31 pm »
And I was worried 1 bar might be pushing it too far.... :oops:
Reply #2July 20, 2006, 01:34:52 am
Dr. Diesel
  • 1341
« Reply #2 on: July 20, 2006, 01:34:52 am »
beautiful!!
now let's see a video of a hard launch and full throttle through 3 or 4 gears! :P
Reply #3July 25, 2006, 03:34:20 am
therabbittree
  • 299
« Reply #3 on: July 25, 2006, 03:34:20 am »
hey that looks like ...ny?  where are you from? and pics of your engine? what the mpg? i been looking at finding one to mess with for a while...did you modify the cly head oiling?
thanks
Deo
\x/ hillfolk!
Reply #4July 27, 2006, 07:18:28 am
2383 GTD
« Reply #4 on: July 27, 2006, 07:18:28 am »
Quote from: therabbittree
thanks
Deo
\x/ hillfolk!
Here is an old video, but it gets the job done:
http://www.komfortwaggon.co.uk/volvosite/vid/244derv.avi
I will have a look for some engine photos, and videos as well.
I am from DC, and the photos are some backwoods roads in Virginia.  Tread lightly and it easily yields 50 mpg.  Even with no regard to mileage, and you still get mid 30s.
There is no reason to mess with any oiling with the engine, and every myth about the engine, has proven to be totally false.  With all the time and evolution of tuning over 10 years time, nothing has cropped up.  In addition, I've had and tuned many engines, and there has been no issues.
They are silky smooth, sound amazing, very easy on the drivetrain due to the close to constant torque output profile, last forever, and make serious power :twisted:
Reply #5July 27, 2006, 08:25:14 am
therabbittree
  • 299
« Reply #5 on: July 27, 2006, 08:25:14 am »
mummn cool yours is a6 cyl and you have ahx40 on it froma cummins 8.3 cool i thought you were the same guy on teh gtd board that had th esupped up 6 or 5 cyl that disappeared from teh board about 2yrs ago..either way im very interested in learning more about your rid and info ..the other guy modified his cyl head to increase oiling for th ecam etc.. that new link doesn't work.
thanks..
keep in touch ..and more specs on your car..so far all i know is its a 6cy vw in the volvo and its manual trans with hx40 turbo...
thanks
Deo
\x/ hillfolk!
Reply #6July 28, 2006, 03:24:01 pm
2383 GTD
« Reply #6 on: July 28, 2006, 03:24:01 pm »
Deo, I am that guy, I read the board frequently, I just do not post that often  8)
The car does have an electric oil pump for pre-oiling, and switch-off oiling, but it is just a precaution, and makes changing the oil a snap.  It also adds an additional 2.5 quarts to the oil volume.
The engine is fully built, has a metal head gasket, as well as studs, and turns a 14mm pump built by me.  Even in stock form, a metal head gasket coupled with the studs allows very high boost levels, driven by the factory 10mm pump.
If you like to know more, just ask me.  The link above is corrected.
