Author Topic: old topic please delete  (Read 10129 times)
September 15, 2004, 06:30:00 am
Smog
  • 160
« on: September 15, 2004, 06:30:00 am »
Injector nozzles for IDI : 1.6GTD
the price will be 80$can each set of 4 nozzles SHIPPING INCLUDED (Express Post 2 days in Canada)
so how many of you guys are interested ?
www.VEG-Injection-Service.com
1.6GTD nozzles (RA/SB )
1.9TD nozzles (AAZ )
0.205mm or 0.216mm TDI nozzles
TDI injection pump seal kit
IDI Pump shaft seal
Reply #1September 15, 2004, 08:22:22 am
caddy
  • 748
« Reply #1 on: September 15, 2004, 08:22:22 am »
gtd nozzle? you mean ra nozzles from the 80hp td?
Reply #2September 15, 2004, 08:25:30 am
Smog
  • 160
« Reply #2 on: September 15, 2004, 08:25:30 am »
Quote from: "caddy"
yes it's for the RA unless you have another suggestion as the order is not sent yet
oui c'est pour le moteur RA que vous avez en Europe, si tu as une autre suggestion de moteur/nozzle tu as juste a me le dire puisque j'ai pas encore passé de commande.
IDI Pump shaft seal
Reply #3September 15, 2004, 08:38:33 am
caddy
  • 748
« Reply #3 on: September 15, 2004, 08:38:33 am »
i know bigger but they need a lot of tune for good work...
they was fitted on range rover2.5td.
i have to found the ref.
i think they need to have bigger break pressure.
Reply #4September 15, 2004, 08:42:23 am
Smog
  • 160
« Reply #4 on: September 15, 2004, 08:42:23 am »
Quote from: "caddy"
first of all I need to know what people want as the minimum order is quite large and I don't want to have a big inventory ($$$).
IDI Pump shaft seal
Reply #5September 15, 2004, 08:46:12 am
caddy
  • 748
« Reply #5 on: September 15, 2004, 08:46:12 am »
yes  off course!
i think for you the best is the ra nozzles  easyer to fit and tune  for evryone!
Reply #6September 15, 2004, 03:08:27 pm
RAMMSTEIN
  • 331
« Reply #6 on: September 15, 2004, 03:08:27 pm »
Caddy, the range rover 2.5td's nozzles don't fit right in there?
What about the 2.5TD from Mercedes?
Blades?
Rammstein
In abscence of light, darkness prevails.
Reply #7September 16, 2004, 01:04:16 am
caddy
  • 748
« Reply #7 on: September 16, 2004, 01:04:16 am »
Quote from: "RAMMSTEIN"
Blades?
the range rover's nozzles  fit nice, but you have to tune a lot for good idle and good fueling.instead of the RA vw's nozzles who are realy "plug'n'play".
in europe we have a lot of td engine , but the 2.5td mercedes is only a 5 cylinder ( or 6  :?:   don't remenber..) and make only about 115 hp or 120 hp.
the range is a 4 cyl with the same power , then i think that the range rover's nozzles are bigger.
so mercedes part are very hard to found because this engine could run more than 700 000 km!!!
Reply #8September 16, 2004, 06:19:12 am
Dr. Diesel
  • 1341
« Reply #8 on: September 16, 2004, 06:19:12 am »
upping the breaking pressure past a certain point is no good. You have to advance the pump timing proportionately to compensate. This makes for a very noisy engine, with too much advance in the higher revs once the internal advance mechanism kicks in. Maybe Giles has some input here?
Reply #9September 16, 2004, 08:36:19 am
caddy
  • 748
« Reply #9 on: September 16, 2004, 08:36:19 am »
Quote from: "Dr. Diesel"
i know that!
but you don't have to change anything in the internal advancewith higer breaking pressure you only have an offset advance timing, so you juste have to adjuste the statique timing !
Reply #10September 16, 2004, 04:10:03 pm
RAMMSTEIN
  • 331
« Reply #10 on: September 16, 2004, 04:10:03 pm »
:mrgreen:
Rammstein
Reply #11September 19, 2004, 05:13:04 pm
ricosuave
  • 244
« Reply #11 on: September 19, 2004, 05:13:04 pm »
what is the part number?  is it the one from here?
http://forums.tdiclub.com/showthreaded.php?Cat=&Board=UBB4&Number=133930&page=&view=&sb=5&o=&vc=1
if so, i may be interested.  what benefit would your new injectors have over my stock 97 1.9 idi (can) ones?
Reply #12September 20, 2004, 04:09:55 am
Smog
  • 160
« Reply #12 on: September 20, 2004, 04:09:55 am »
Quote from: "ricosuave"
il will be nozzles made for the 1.6td GTD; I can't tell if they are upgrade for the 1.9td.
but is your pump maxed out ?
IDI Pump shaft seal
Reply #13September 20, 2004, 05:45:09 am
caddy
  • 748
« Reply #13 on: September 20, 2004, 05:45:09 am »
Quote from: "Smog"
what is for you the 1.6 gtd?
my first car was a 1.6gtd golf but it have only 70hp. (JR engine)
then you can have ( in europe) the 1.6td 80hp ( intercooler+turbo watercooled) it have 80hp. ( RA & SB engine)
this link talk about the RA injector.
and we usualy use it like an upgrade for the 1.9td engine ( aaz).
Reply #14September 20, 2004, 07:58:03 am
Smog
  • 160
« Reply #14 on: September 20, 2004, 07:58:03 am »
Quote from: "caddy"
I talk about the RA engines.. but nozzles are useless if the pump is not at maxe on the fueling settings (can't bring the Idle down to 900rpm)
IDI Pump shaft seal
