Author Topic: a few questions  (Read 3976 times)
July 11, 2006, 10:46:43 pm
bustedfoxwagen
  • 31
    • http://www.wagenwerks.net
a few questions
« on: July 11, 2006, 10:46:43 pm »
hey guys im new to the diesel world so please bare with me...
i got a 92 eco doesel jetta with a 1.6t
i wanted to know what i could do performance wise.. i have done a itg cone filter and 2" straight pipe all the way out... wanted a new turbo, would mk3 tdi turbos fit or even 1.8t turbos? what injectors should i run and is it worth buying the performance nozzels? would a down pipe make a difference? please point me in the right dirrection on what to do, thanks alot
-Ben
92 eco diesel jetta
Reply #1July 11, 2006, 10:47:29 pm
bustedfoxwagen
  • 31
a few questions
« Reply #1 on: July 11, 2006, 10:47:29 pm »
sorry ment to post in idi.. sorry
92 eco diesel jetta
Reply #2July 12, 2006, 06:00:54 am
therabbittree
  • 299
a few questions
« Reply #2 on: July 12, 2006, 06:00:54 am »
your small eco diesel turbo is still much bigger then a tdi or 1.8t turbo... you can swap to a 1.6td non eco diesel turbo for a bigger turbo.... a down pipe makes a big differenc e..go bigger on the exhaust and get rid of the muffler..get a egt and bopost guage and adjust your inj pump for more fuel
later
Deo
Reply #3July 12, 2006, 06:20:47 am
bustedfoxwagen
  • 31
a few questions
« Reply #3 on: July 12, 2006, 06:20:47 am »
i have already ran 2" exhaust all the way out with no muffler, so your saying get a turbo off like a 89 regular turbo diesel? and where would i hook the boost gauge to i can't find any lines with boost/vac
92 eco diesel jetta
Reply #4July 12, 2006, 03:54:00 pm
therabbittree
  • 299
a few questions
« Reply #4 on: July 12, 2006, 03:54:00 pm »
deleted
Reply #5July 12, 2006, 03:54:49 pm
therabbittree
  • 299
a few questions
« Reply #5 on: July 12, 2006, 03:54:49 pm »
I normally drill and tap for a 1.9 npt nipple to run a boost line off the intake manifold.. some td intake manifolds have a little nipple off of the intake elbow you can tee into.. also you can undo the 10 mm banjo bolts for the waste gate pressure lines and either cut the metal pipe and slip and hose over it or get a nipple that threads into the hole for a hose ..then run those in to the cabin and attach to adjustable air pressure regulator  from say a air compressor...and then you can dial in you boost level... if you don't want to tap the intake for a boost line , tee into the cold side waste gate line for adj boost controller you make....
diesels have no vacuum... ie no throttle plate ...dril and tap your exhaust manifold before the turbo for the egt gauage ...if you don't have a egt gauge or don't want to install one ..then don't touch the injection pump.
Thanks
Deo
\x/ hillfolk!
