Author Topic: It has begun...  (Read 3329 times)
July 10, 2006, 06:18:30 pm
anarchyx34
It has begun...
« on: July 10, 2006, 06:18:30 pm »
Before you I behold the centerpiece of my diesel swap project. I'm quite happy right now as the motor seems to be in pretty clean shape. Now, I'm still a bit unfamiliar with these engines, so I snapped some pics hoping that someone here can tell me what these things are and what they do.
First, the beast..
Now the questions.
This is on the side of the cyl. head, my gas engine dosent have one of these. I'm assuming it's for the glow plug relay?
WTF is this??? Located on the side of the block and would be facing the firewall
Any idea where these used to go?
Not sure what this is/was either.
Thanks!!!!
Reply #1July 10, 2006, 06:41:12 pm
QuickTD
  • 1156
Re: It has begun...
« Reply #1 on: July 10, 2006, 06:41:12 pm »
Quote from: "anarchyx34"
Depends on what the engine came out of. Some had the glow plug sensor here some had the guage sensor in that location. You'll have to offer up more info.
Block heater.
The largest and lowest one is the bottom rad hose. The upper one on the water pump is the heater return, the cut one on the oil cooler would also "t" into the heater return hose. In a front drive installation there would be a metal pipe that snakes around to the rear of the engine to reach the heater hose connection. The hacks that removed it cut up the incredibly expensive "t" hose that connects the oil cooler and heater return to the metal pipe...
It's the vent for the bottom of the LDA (boost enrichment diaphram), do not connect anything to it just point the "tit" downwards so crap doesn't get in it.
Reply #2July 10, 2006, 08:36:40 pm
anarchyx34
It has begun...
« Reply #2 on: July 10, 2006, 08:36:40 pm »
Thanks for the reply! So I need to get a new T-hose for the oil cooler, and the metal pipe if mine's missing (didnt really notice). Any good sources for this online aside from the dealer?
Reply #3July 10, 2006, 08:47:05 pm
nkb
  • 154
It has begun...
« Reply #3 on: July 10, 2006, 08:47:05 pm »
i can get that T pipe that has replaceable hoses for 60$ canadian. no more molded one piece crap
2004 Jetta TDI
1997 GMC Suburban 6.5td
2002 S-10 AWD V8 turbo, Sy-clone
1986 S-10 LT1
Reply #4July 11, 2006, 03:42:31 pm
insdtanoodles
  • 148
It has begun...
« Reply #4 on: July 11, 2006, 03:42:31 pm »
yeah I bought a "T" hose from altrom and all it had was 3 different hoses clamped to a solid plastic "t" and it was only 38 bucks I think. It is actually sitting in my trunk right now.
1996 vw jetta AAZ
Reply #5July 11, 2006, 05:24:45 pm
andy2
It has begun...
« Reply #5 on: July 11, 2006, 05:24:45 pm »
The white "switch" on the cyl head is used on cars with A/C its a temp switch that opens the A/C clutch circuit if the coolant temp gets above a certian safe max temperature.Definitely a must for an A/C equiped car,otherwise just ignore it :wink:.
Reply #6July 11, 2006, 06:17:50 pm
It has begun...
« Reply #6 on: July 11, 2006, 06:17:50 pm »
the worst stage of a motor swap is when you have only 1 more step to go and it is taking longer than expected and you are just excited to drive the car and all you wanna do is drive the car but you can't drive the car cause of it.  happened to me effing exhaust all i wanted to do was drive the turbo
Reply #7July 12, 2006, 04:59:16 am
nkb
  • 154
It has begun...
« Reply #7 on: July 12, 2006, 04:59:16 am »
Quote from: insdtanoodles
38$$?? wow my parts guy must be ripping me off, whats the part number off that piece you have?
2004 Jetta TDI
1986 S-10 LT1
Reply #8July 12, 2006, 12:13:56 pm
anarchyx34
It has begun...
« Reply #8 on: July 12, 2006, 12:13:56 pm »
OK, since mine didnt come with this 3-way hose and pipe, and I've never seen one before, I need help figuring out what I need. I have ETKA (german language unfortunately). Here's the parts explosion I pulled up.
[/img]
Reply #9July 12, 2006, 12:51:46 pm
anarchyx34
It has begun...
« Reply #9 on: July 12, 2006, 12:51:46 pm »
OK, I printed it out and looked a little closer, and here's what I found.
http://www.worldimpex.com/item_detail.html?sku=40587
http://www.worldimpex.com/item_detail.html?sku=5034
http://www.worldimpex.com/item_detail.html?sku=42157
Seems about right dosent it? The only thing that concerns me is the distribution pipe, because worldimpex says "except turbo", but ETKA shows that part # for engine code MF, which is turbo. I cant imagine them being any different. So should I order these?
