Author Topic: Choices, choices........  (Read 2240 times)
July 07, 2006, 02:21:00 pm
redbaron
  • 21
« on: July 07, 2006, 02:21:00 pm »
Hello im new to all this diesely goodness having owned only petrol gti volkswagens along the line.
Ive recently bought a mk1 caddy to look cool in but as its a 1.6 NA diesel its not exactly the fastest thing in the world. Ive done a bit of research and have decided that a 1.9aaz TD lump is the way to go, ive had a mk3 golf with this engine before but it wasnt very well and when I discovered I could wind up the fuelling to make it faster it decided it would shear its crank pulley in protest!  :cry:
Basically what im after is how to build a reliable, use everyday thrape the tits off without breaking type engine. I vaguely remember reading that you can use the pump/metering head bits from a 1.6 (D/GTD?) in the aaz pump to make it betterer and that you can wind up the fuelling/wastegate thingy (dont really understand) to get about 100bhp?
which would be nice  :D
anyone gone down this route before?
thanks in advance!
Reply #1July 07, 2006, 07:19:09 pm
« Reply #1 on: July 07, 2006, 07:19:09 pm »
I think you put the TDI crank on the AAZ engine and then you're good to go
