Author Topic: No Power  (Read 4720 times)
July 07, 2006, 12:50:29 am
ezekiel
  • 147
No Power
« on: July 07, 2006, 12:50:29 am »
I have an 82 rabbit pickup and it keeps getting slower every time I drive it.  I can barely keep it at 60mph now.  I know it's capable of it, yesterday it had more power than it had ever had the whole time I've owned it.  I could accelerate up a slight incline in 5th.  Now I can't even do it in 4th.
It seems like theres more power at partial throttle than full throttle.  It feels like the more I push down on the pedal, the slower it goes.
any ideas?
thanks guys.
Reply #1July 07, 2006, 09:36:18 am
Powjetta
  • 152
    San Diego CA
No Power
« Reply #1 on: July 07, 2006, 09:36:18 am »
Does the fuel filter need changed?  Does it make more smoke?
'86 jetta 2 dr Turbo diesel K24 - sold
'94 GMC 6.56TD - sold
Reply #2July 07, 2006, 01:57:37 pm
ezekiel
  • 147
No Power
« Reply #2 on: July 07, 2006, 01:57:37 pm »
no smoke, and it has been changed recently
I'm going to try cleaning the lines and injectors this weekend, see if that clears things up.
I did add some diesel power? stuff, it may have knocked some sludge out.  I'm almost 100% certain the lines and injectors have never been cleaned in its 178k miles.  I bet the injection pump could use some timing as well.
Reply #3July 07, 2006, 08:10:55 pm
No Power
« Reply #3 on: July 07, 2006, 08:10:55 pm »
is it getting harder to start as well?
Reply #4July 08, 2006, 12:39:23 am
ezekiel
  • 147
No Power
« Reply #4 on: July 08, 2006, 12:39:23 am »
it's hard to start when it's warm, when it's cold, no problems, starts right up.
Reply #5July 10, 2006, 12:00:03 am
ezekiel
  • 147
No Power
« Reply #5 on: July 10, 2006, 12:00:03 am »
well, I cleaned out the solid lines to the injectors, the injectors themselves, and replaced the return lines (rubber w/ mesh)
definitely has more power, but I still keep running into a brickwall when going up hills.  I know I'm not supposed to expect much from the little 1.6NA, but it's not a gradual loss of power, it's a sudden loss of power.
I think I'm going to get the GreaseWorks.org viton hose kit, and drop the tank, totally scrub the inside of the tank, fix the fuel sender, clean the mesh, and brakleen/blow out all the solid lines and see what happens.  Also install my tach so I can safely (to me) take off the rev limiter.
