Author Topic: Water Injection  (Read 34047 times)
Reply #30July 10, 2006, 09:22:25 am
BellCityDubber
  • 251
Water Injection
« Reply #30 on: July 10, 2006, 09:22:25 am »
Well...
this weekend I took a trip to the wreckers and found some items for my water/alcohol injection setup... I have a new intake tube that I can mangle up..... I got another washer fluid bottle & pump, and I've yet to find an apporpriate nozzle... and I'm thinking a switch too... but we'll see..
Reply #31July 10, 2006, 09:23:21 am
Benjamin
  • 485
Water Injection
« Reply #31 on: July 10, 2006, 09:23:21 am »
@greggearhead: how do i know i put to much water in the cilinders???
how do i know i use a to big nozzle?
Greetz, Benjamin
Must make +250hp
Reply #32July 10, 2006, 02:31:20 pm
greggearhead
  • 153
Water Injection
« Reply #32 on: July 10, 2006, 02:31:20 pm »
I can't tell you how much fluid to use with a different design nozzle, only the nozzles we have experience with.
For our nozzles, on an IDI TD with about 125-150hp, I would use a 175 or 225ml/min nozzle.  More or less for specific application issues (larger for no intercooler, smaller for a very efficient turbo and large intercooler, etc).
With other nozzles, you may have to go larger to try and get as much temp reduction, but it may not tolerate as much fluid.  Difficult to say.
Caddy (TD Project), Caddy 1.6D, etc etc.
  Snow Performance Water-Methanol Injection
Reply #33July 10, 2006, 04:26:21 pm
hillfolk'r
  • 1532
Water Injection
« Reply #33 on: July 10, 2006, 04:26:21 pm »
i dont know flow rates and all that stuff,but when i compared the amount of water sprayed in a cup between my 2 different nozzles
ihit the button for 10 seconds for each test
each time,
i had about enough water to fill a "standard spray paint top/cap" like about 1/3 of the way up i wanna say
i should have measured it in a measured cup for you guys
but ijust wanted to compare flow rates on each of my jet  setups
i found out my restriction is the 1/8 inch copper guageline that im using
you could probablyalmost use that,if it sprayed nice
my single jet would shoot 5-7 feet (2-2.5 meters roughly) or so
Throttle cables ftw
Reply #34July 17, 2006, 11:30:02 pm
BellCityDubber
  • 251
Water Injection
« Reply #34 on: July 17, 2006, 11:30:02 pm »
okay, so at our weekly vw meet a few guys and I were tossing around ideas...
someone said a high pressure pump would work better and try to find the best atomization as possible.... so we've come up with the following...
1. Would a CIS injection pump work well for high pressure, seeing as it's ~80psi? and if so, would it or would it not work due to the fact that it may not work well with water as it wasnt designed for moving water.
2. Would a NOS fogger from an old NOS kit work? I wouldnt see why not...
Reply #35July 18, 2006, 12:29:52 am
Benjamin
  • 485
Water Injection
« Reply #35 on: July 18, 2006, 12:29:52 am »
i dont know what means CIS, problebly its becouse i just can talk basic english  :?   i think a 80psi pump is not enough, you have to become a fine mist, i would say you need to have something like 150psi, i realy suggest to get one above 100psi!
When using a waterpump, i dont know (its just an idea) can it beat methanol?
as far as i know, the injector will give you a angle, an a quantity, you may not put to much water in the engine! but a flow test on this NOSfogger would be easy  :wink:  i try to take some pics when my system is working for the angle. i think as long you have a angle its good, as long you get a fine mist its good.
Greetz, Benjamin
Must make +250hp
Reply #36July 18, 2006, 03:10:08 pm
BellCityDubber
  • 251
Water Injection
« Reply #36 on: July 18, 2006, 03:10:08 pm »
Quote from: "Benjamin"
as the post above states what a CIS pump is.... it's not a waterpump. and if hillfolk'r is using a windscreen washer pump, I'm sure that a CIS pump would deliver much more pressure.
Reply #37July 19, 2006, 01:24:21 am
Benjamin
  • 485
Water Injection
« Reply #37 on: July 19, 2006, 01:24:21 am »
Quote from: BellCityDubber
Quote from: Benjamin
Most gasser pumps dont live long when they have to transport water. A friend of my did it. Anyway, you can give it a try!
My old 1.6Fiat had an 15psi pump, my brother his FiatTurbo gasser got a 45psi pump. i think a vw will be +- the same.
Greetz, Benjamin
Must make +250hp
Reply #38July 19, 2006, 07:56:29 am
greggearhead
  • 153
Water Injection
« Reply #38 on: July 19, 2006, 07:56:29 am »
The CIS is a good high-pressure pump, but its internals won't last long with water, and won't last at all with methanol.
Reply #39July 19, 2006, 02:57:09 pm
BellCityDubber
  • 251
Water Injection
« Reply #39 on: July 19, 2006, 02:57:09 pm »
Quote from: "greggearhead"
Yeah, the CIS fuel pumps are 80 psi, but if they wont last long with water I guess I'm a little bit F'd up that alley.. maybe I'll have to use something along the lines of what hillfolk'r's got
Reply #40July 19, 2006, 03:04:07 pm
Benjamin
  • 485
Water Injection
« Reply #40 on: July 19, 2006, 03:04:07 pm »
Quote from: greggearhead
OFFTOPIC  :oops:  does anyone know how much cc/min it can flow?
Greetz, Benjamin
Must make +250hp
Reply #41July 19, 2006, 06:18:25 pm
BellCityDubber
  • 251
Water Injection
« Reply #41 on: July 19, 2006, 06:18:25 pm »
Greetz, Benjamin
I found a great page here
http://www.auto-solve.com/mech_inj.htm#MFI03
that indicateded the following
The pump is capable of producing a pressure of 8 bar (120 psi) with a delivery rate of approximately 4 to 5 litres per minute.
Within the pump is a pressure relief valve that lifts off its seat at 8 bar to arrest the pressure should the filter, fuel lines or other eventualities cause it to become obstructed. The other end of the pump (output) is home to a non-return valve that, when the voltage to the pump is removed, closes the return and maintains pressure within the system, as illustrated in figure 6.1.
The normal operating pressure within this system is approximately 5 bar (75 psi) and at this pressure the current draw on the pump is 5 to 8 amps.
totally off topic, but a really good pump for water injection IF it would hold up to the differences between gasoline and water/alcohol/methanol... etc.
and aint that a *** because the cis pumps are a dime a dozen around these parts
Reply #42July 20, 2006, 03:19:35 pm
greggearhead
  • 153
Water Injection
« Reply #42 on: July 20, 2006, 03:19:35 pm »
We sell our pumps seperately - we have 150psi pumps and 220psi pumps, fyi.  They last with straight water or 50/50 water-methanol.
Reply #43July 21, 2006, 08:52:55 pm
BellCityDubber
  • 251
Water Injection
« Reply #43 on: July 21, 2006, 08:52:55 pm »
although it would be nice to have such equipment, I do not have the adequate funds for such a device.... a CIS pump would be cheap.. like.. 10 bucks cheap, same with alot of other pumps.....
as I stated on much earlier in the thread, I'm trying to do this as low cost as possible, because I'm basically a starving student
Reply #44August 04, 2006, 04:11:26 am
Benjamin
  • 485
Water Injection
« Reply #44 on: August 04, 2006, 04:11:26 am »
those pics i ever promised  :oops:  , this is the angle (of my 300cc injector)
@BellCityDubber: did you tried something out with a CIS pump?
Greetz, Benjamin
Must make +250hp
