Boost How much?
Topic: Boost How much? (Read 5547 times)
September 10, 2004, 09:21:06 am
Rat407
Authorized Vendor
Boost How much?
September 10, 2004, 09:21:06 am »
Just wanted to know. I have the KKK K14 turbo on my 91 Jetta 1.6, the most I can get out if it boost wise is 5psi max, How much should I be getting?
Thanks
AMS
OIL
Synthetic Lubricants & Filtration Systems, Click Here
Wholesale pricing available!
1991 Jetta ECO TD
September 10, 2004, 10:29:02 pm
Blades
Boost How much?
September 10, 2004, 10:29:02 pm »
9 to 12
K14 ?
sure it's not a K24 ?
September 11, 2004, 01:36:16 pm
dieseltech
Boost How much?
September 11, 2004, 01:36:16 pm »
eco diesels ran 5-7psi your in the ballpark, with proper boost controller, up near 12-15 psi possable.
stock was real low
91 and 92 jettas were not real turbo diesels. the turbo was only there to help reduse visable soot out the tail pipe by adding more air to the engine
86 td jetta power everything dd (update off the road for major resto). 97tdi bare bones, DD
and a private junkyard of various other vw/audi/bmw/peugeot/volvo/toyota diesels!!!
Cummins has the worlds record for being the most efficient engine ever!!!!!
for converting fuel into noise!
September 11, 2004, 03:06:51 pm
Blades
Boost How much?
September 11, 2004, 03:06:51 pm »
ohhhhhh
it's a 91 USA ECODiesel (not the same as the the canadian 91 TD)
it's the detuned 58hp version.
/me was confused.
September 13, 2004, 03:45:01 am
Rat407
Authorized Vendor
Boost How much?
September 13, 2004, 03:45:01 am »
So to make this a true turbo diesel I would need a TD injection pump and bigger turbo? Would the K24 turbo be a direct bolt on?
Thanks
AMS
OIL
1991 Jetta ECO TD
September 13, 2004, 08:59:16 am
dieseltech
Boost How much?
September 13, 2004, 08:59:16 am »
i forget if the eco has oil squirts under the pistons, if so yes bolt up the pump and turbo and enjoy.
on my eco diesel i left the small turbo and only put the td pump on, but i raised the turbo boost pressure to about 12-15psi (about max for the lil'turbo) and modded the pump a bit (extra fuel,adv timing,changed lda spring to lighter spring etc). i am real happy with the results with the smaller turbo, as i now have full boost about 2,000rpm and a more "useable" powerband. its still no true td bit its a LOT faster than it was stock.
my 86 td has full boost above 3,000
so i gain 1,000 rpm with the smaller turbo on my 91.
September 13, 2004, 05:23:12 pm
dieselpower
Boost How much?
September 13, 2004, 05:23:12 pm »
hey,
i kno its a little off topic but i decided to post here instead of making a new thread. anyway, does anyone know how much boost a stock 1.6l TD can handle? im not tallkin about the turbo cuz thats getting replaced but i mean the block, head ect.
thanks for the help
84 rabbit 1.6TD
because real cars don't have sparkplugs
September 19, 2004, 07:55:10 pm
dieseltech
Boost How much?
September 19, 2004, 07:55:10 pm »
i've shoved 35 psi in one but i did not own the car long enough before i got "T" boned in it. it was at 35psi for about a month, then i got hit.
but it held up with 35 for that time
Boost How much?
