Author Topic: Valve guides  (Read 5112 times)
June 30, 2006, 04:21:58 am
zooky
  • 71
Valve guides
« on: June 30, 2006, 04:21:58 am »
I replaced my sloppy valve guides, kind of a PITA. After pressing them in the valves wouldnt fit, is an interference fit into the head so they got squeezed closed a tad. I was afraid that. The specs calls out a max 'rock' of .051 for a wear limit (for used components). I set the 'rock' to .020-.025. Does that sound reasonable for new valves and guides?
Reply #1June 30, 2006, 04:44:03 pm
duffer
  • 164
Valve guides
« Reply #1 on: June 30, 2006, 04:44:03 pm »
Actually, a similar thing happened to me.
I ordered a set of new vales and valve guides
And, when I got them, the valves wouldn't
fit in the guides.
Turned out I'd been given the 7mm guides
found on the 15V gasoline engine.
Reply #2June 30, 2006, 05:47:16 pm
zooky
  • 71
Valve guides
« Reply #2 on: June 30, 2006, 05:47:16 pm »
they fit fine before installing them but that may be engineered to compress to 7mm when insalled. Oh well, they fit now
Reply #3June 30, 2006, 10:53:17 pm
moosiah
  • 106
Valve guides
« Reply #3 on: June 30, 2006, 10:53:17 pm »
When I installed new guides they did'nt fit either .....  it's common for this to happen, your supposed to run a reamer thru them after installation to size them. proper clearance is built in.  :)
'81 Frankenbunny: part rabbit, sirroco, golf ,caddy cabrio ,jedda and ! ford teimpo! w a little more Audi and soon some Peogeot too!!!!
Reply #4July 09, 2006, 01:51:38 am
  • 2926
valve guides
« Reply #4 on: July 09, 2006, 01:51:38 am »
I've heard that you aren't supposed to press the old valve guides out because it drags aluminum with it. My mechanic suggested drilling them until they are thin then pulling them out.
 Chill them when putting them in.
 Not related to your problem but thought it needed to be mentioned.
Reply #5July 10, 2006, 12:06:10 pm
duffer
  • 164
Valve guides
« Reply #5 on: July 10, 2006, 12:06:10 pm »
Yes, when I worked on Jaguars (my old 1958 XK150
and my two MkII's) the valve guides can be pressed
out, but the new valve guides are oversized outside diameter
and the cylinder head holes are reamed to provide an
interference fit with the new o/s guides.
This addresses the issue you describe, above, vis a vis
the removal of some of the cyl.head material when removing
the old guides.
I would think that on a VW Diesel, this might be counselling
for perfection, though.
