Author Topic: 1.6 IDI Waterjacket Improvement  (Read 24809 times)
Reply #30May 07, 2008, 07:51:51 pm
« Reply #30 on: May 07, 2008, 07:51:51 pm »
Maybe another material and made from scratch? Or call Fel pro and see what they would do for us? I used to work in an injection molding place and we used beryllium copper for the molds. The main reason was because it didn't really expand or expand as much as anything else would when such high heat and presure were applied...I wonder if someone makes a gasket or could out of that. Once again it is just a thought
Reply #31May 09, 2008, 10:38:40 pm
  • 2932
« Reply #31 on: May 09, 2008, 10:38:40 pm »
have my 1.9 HG on hand. I was planning on using it but was thinking of doing the block mod. Any one have the pictures from the front of this post saved?
 If you have a 1.9 headgasket,... I think it has the holes in it..
 Down in the "V" between the cylinders, on each side of center....
 6 holes?
Reply #32November 16, 2008, 07:50:35 pm
53 willys
« Reply #32 on: November 16, 2008, 07:50:35 pm »
What size drill bit are you guys using??? I'm at work and cant see the pics...is 1/8" drill big enough???
Reply #33November 16, 2008, 08:01:36 pm
  • 3468
    • McScrubbins Body Wash
« Reply #33 on: November 16, 2008, 08:01:36 pm »
Has anyone made a jig for driling these while the block is still in the car? I want to make one but if someone has already done this is would be a great template. Please let me know!
Reply #34November 16, 2008, 08:47:03 pm
53 willys
« Reply #34 on: November 16, 2008, 08:47:03 pm »
Quote from: "Smokey Eddy"
the jig is the 1.9 AAz headgasket....if your doing this mod you will already have the jig! :wink:
Reply #35November 16, 2008, 08:50:58 pm
  • 3468
« Reply #35 on: November 16, 2008, 08:50:58 pm »
by jig i mean a ways of drilling the block without using a drill press or drilling by hand.
I mean a jig that adheres to the block and you stick your drill into like guides and just push down while drilling and the guides hold you true and straight
or since its just half an inch do most people just say f*** it and drill by hand "yeah that's straight enough..." *wrrrrrrrrrr* crack. "whoops. drilled into the cylinder wall... oh well it's not important."
I guess i'm really asking how big is the water jacket. If you start at the right point do you have to be extremely deficient to miss it drilling by hand?
Reply #36November 16, 2008, 09:51:08 pm
  • 2932
« Reply #36 on: November 16, 2008, 09:51:08 pm »
You should be able to slide something into the waterjacket, next to where you intend to drill and feel what's behind where you are drilling.
 I don't think the hole needs to be real straight,... just needs to line up with the hole in the gasket.
Reply #37November 17, 2008, 02:51:09 pm
monomer
  • 414
« Reply #37 on: November 17, 2008, 02:51:09 pm »
Center punch and an airdrill is all you need.
if your worried about being perpendicular; use a ve-block to make sure the drill is straight.
A drill bushing setup would be overkill; But I could make some up after I get my 1.9 head here.
(<---Tool/Die maker; specializing in composite hand-apply drill fixtures for Lockheed Martin)
www.michiganvw.org
Reply #38November 17, 2008, 03:41:11 pm
  • 3468
« Reply #38 on: November 17, 2008, 03:41:11 pm »
Quote from: "monomer"
Ahhh! excellent. I think my old high school shop has one. Maybe i can use it!!!
thanks for the tip. Exactly what i asked for!!!
thanks fatmobile too. I appreciate all advice!!!
Cheers guys.
Reply #39November 17, 2008, 04:15:01 pm
« Reply #39 on: November 17, 2008, 04:15:01 pm »
here's a tip - put plastic over the block and put tape over where you're drilling... this will help keep any bits from getting into the bores  :wink:
or maybe someone else has a better idea
Reply #40November 17, 2008, 04:38:03 pm
monomer
  • 414
« Reply #40 on: November 17, 2008, 04:38:03 pm »
Cheers guys.
any tool supply shop will sell them.
a simple block should be no more than $20. Harbor freight may even have them.
A circular level on the back of the drill will also work (assuming the head is sitting level)
www.michiganvw.org
Reply #41November 17, 2008, 07:37:32 pm
53 willys
« Reply #41 on: November 17, 2008, 07:37:32 pm »
I did my head last night...1/8" drill is what I used I then deburred the holes.
I used green painters tape and taped everything just like mentioned in this thread....it went SUPER EASY with my 18volt dewalt drill...I'm gonna do the block tomorrow..I'm gonna do it the same way as well..hand drill with the cordless dewalt..
wish me luck!!..lol
Reply #42November 18, 2008, 07:48:52 am
« Reply #42 on: November 18, 2008, 07:48:52 am »
Quote from: "53 willys"
wish me luck!!..lol
Grease the drill bit to keep metal in the block to a min..
Reply #43November 19, 2008, 07:33:44 am
« Reply #43 on: November 19, 2008, 07:33:44 am »
Wait, so the head needs drilled too?
Reply #44November 19, 2008, 07:36:35 am
53 willys
« Reply #44 on: November 19, 2008, 07:36:35 am »
Quote from: "lord_verminaard"
yes for the 6 holes around the water jacket yes you will need to drill holes in the head and block.
