Author Topic: Temperature sender on GTD turbo - wiring???  (Read 2132 times)
June 21, 2006, 06:50:25 am
regcheeseman
  • 714
« on: June 21, 2006, 06:50:25 am »
AS the muppets that stripped my GTD out at the breakers cut all the wires at the plugs I'm left with a problem.
I'm installing the motor using my A1 caddy loom and am two plugs short - the water pump and the turbo temperature sender
What does the temperature sender on the turbo do? Control a different temp gauge or warning light or does it switch the auxillery turbo coolant pump off/on?
Can anyone help with a wiring diagram?
Reply #1June 21, 2006, 02:33:22 pm
mk1vdub
  • 93
« Reply #1 on: June 21, 2006, 02:33:22 pm »
the second one - switches the aux turbo water pump on.
I wired mine up to a permanent live (I think I went straight to the battery, but you could probably go to the fuse box somewhere if you wanted a more factory look/setup) so that it could run even when I swiched off (when the switch triggered obviously) to keep the coolant flowing round the turbo
1983 mk1 golf GTD
1980 mk1 scirocco Gli, in bits, in the garage, awaiting full restoration
Reply #2June 22, 2006, 01:42:27 am
regcheeseman
  • 714
« Reply #2 on: June 22, 2006, 01:42:27 am »
Cheers for that!
I might add an indicator light somewhere to let me know it is running, else you would never know if the switch was actually working.
