Author Topic: Rabbit TD vs chipped A3 jetta TDI  (Read 7879 times)
June 17, 2006, 07:04:53 pm
Dr. Diesel
  • 1341
« on: June 17, 2006, 07:04:53 pm »
I'll try to keep it short.
Changed the rad in a friend's A3 TDI jetta today. Went out for a comparison run after. No competition. Every gear, the rabbit pulled futher and further away. And this was from a rolling start (breaking in the kevlar disc) From a dead stop I'd have ruined him.
I figured that with the way this thing runs, the wastegate must be buggered up, feeding the engine high boost. I hooked up a temporary boost gauge, and sure enough... I was wrong! Bang on 10 psi. This car's gonna be insane in the later stages of development...
Reply #1June 24, 2006, 05:53:14 am
Slave2School
  • 531
Nice :D
« Reply #1 on: June 24, 2006, 05:53:14 am »
What mods do you/he have to the cars?  and what kind of chip did he have?  (Good job btw...i'm not sure how my portly beast would do against an older car).
2002 ford focme wagon
Reply #2June 24, 2006, 05:34:16 pm
Dr. Diesel
  • 1341
« Reply #2 on: June 24, 2006, 05:34:16 pm »
not sure what chip he has.
The rabbit has a stock AAZ engine, 2.5" exhaust, T2 turbo, 10 psi, mild govenor tweak.
Reply #3June 25, 2006, 04:40:29 pm
Slave2School
  • 531
« Reply #3 on: June 25, 2006, 04:40:29 pm »
Sounds something like what my friend Chris is doing with his car.  He's got his set up to spike to about 27psi though and I think it holds 22ish :D  It's a fun little sleeper car.
Reply #4June 27, 2006, 10:34:07 pm
Wingaman
  • 7363
    • http://www.dmfdiesel.com
« Reply #4 on: June 27, 2006, 10:34:07 pm »
I got an AAZ with a T2 too, running at 14lbs peak at 15psi without intercooler.
Cost me alot of tires :shock:
1-2 it's slipping, on wet 1 to 4 it's splipping at WOT.
371-B, Ch. Ste-Marie
Ste-Marthe QC J0P 1W0
Reply #5September 28, 2006, 12:09:21 pm
A2TD
Re: Rabbit TD vs chipped A3 jetta TDI
« Reply #5 on: September 28, 2006, 12:09:21 pm »
Quote from: Dr. Diesel
A chipped MK3 will run at best a 17.5 in the quarter........... a very easy kill with a rabbit, even if it only has 75hp  :D
Reply #6September 28, 2006, 04:39:26 pm
Dr. Diesel
  • 1341
« Reply #6 on: September 28, 2006, 04:39:26 pm »
Quote from: A2TD
ok then... consider this post deflated.   :?
Reply #7September 28, 2006, 06:57:05 pm
SMOKEYDUB
  • 630
« Reply #7 on: September 28, 2006, 06:57:05 pm »
well atleast you car LOL used to be your car is 400 times better. :D
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
