Author Topic: RPM's vs Speed  (Read 3413 times)
June 14, 2006, 07:48:31 am
lesharoturbo
  • 78
RPM's vs Speed
« on: June 14, 2006, 07:48:31 am »
Could someone post what heir RPM's are at say 60 MPH and 75MPH?
I am thinking of swapping a diesel into my auto Montero and need to see if the engine speed in top gear is condusive to a diesel powerband.  Currently I see about 2400 @ 60 and just over 3000 @ 75.
I know there are other considerations with the tranny and the torque converter but I will deal with these later.  The good news is the tranny has a mechanical (cable) kickdown instead of electronic.  I just don't know about the lockup on the TC.
Thanks
Bernie
Reply #1June 14, 2006, 10:50:49 am
VwPodRacer
  • 22
RPM's vs Speed
« Reply #1 on: June 14, 2006, 10:50:49 am »
I drive a 97 1.9TD jettta with a 020 tranny and my RPM's is around 3000 at 60mph/100kms in fifth gear.
Reply #2June 14, 2006, 05:22:20 pm
tylernt
  • 344
RPM's vs Speed
« Reply #2 on: June 14, 2006, 05:22:20 pm »
Quote from: VwPodRacer
Dang that seems high. My FF code transmission does ~2600rpm @ 65mph and a titch over 3000rpm @ 75mph.
You can see what some of the various VW trannies do here:
http://scirocco.org/gears/
Just plug the numbers into the calculator.
Reply #3June 15, 2006, 10:42:49 am
VwPodRacer
  • 22
RPM's vs Speed
« Reply #3 on: June 15, 2006, 10:42:49 am »
sorry my bad just got home with my car and its about 2500 at 100kms
Reply #4June 15, 2006, 11:27:46 am
RPM's vs Speed
« Reply #4 on: June 15, 2006, 11:27:46 am »
is 0.71 the lowest ratio for 5th gear you can get?  Any mods out there to lower that???
Reply #5June 15, 2006, 12:10:29 pm
tylernt
  • 344
RPM's vs Speed
« Reply #5 on: June 15, 2006, 12:10:29 pm »
There is a .68 that you can get from somewhere. There was a thread on it on VWVortex but their forums just got messed up so it may be gone.
Reply #6June 15, 2006, 01:44:52 pm
Re: RPM's vs Speed
« Reply #6 on: June 15, 2006, 01:44:52 pm »
Quote from: lesharoturbo
Bernie
Thats almost exactly what I see in 5th in my 3200LB. Volvo, but most Auto trans cars came with a little  steeper gearing
Reply #7June 15, 2006, 07:25:02 pm
hillfolk'r
  • 1532
RPM's vs Speed
« Reply #7 on: June 15, 2006, 07:25:02 pm »
my 7h?(from a 84 jetta td)7 whatever,i forget
 i know its at like 3-3100 at 80 mph,thats with 195-60-14s on the front
and like 2800 or so at 75,ill check goin to work tomorrow, to  be sure igot some good numbers here :wink:
Throttle cables ftw
