Author Topic: 1.6/1.9TD hybrid, few questions.  (Read 5003 times)
June 13, 2006, 03:41:15 am
Black Smokin' Diesel
  • 656
« on: June 13, 2006, 03:41:15 am »
I've found a possibly good 1.9TD head to put on my 1.6TD project. The 1.6 block is from a hydro engine so there are no headgasket issues (go the metal one for a 1.9TD, three notches).
I was wondering about injectors. IIRC, 1.9 injectors are taller and dual stage while 1.6 are shorter and single stage. I have a set of rebuilt 1.6 injectors with GTD nozzles. Is there any issues using those with the 1.9 head? My guess is it's ok to use them but if not, I'll get the 1.9 injectors with the head.
Also, I got a complete gasket set from german auto parts for a 1.6TD head, will it fit the 1.9 head? Obviously the VC gasket is different but I'm wondering about valve stem seals and all the rest. Anyone know?
Last but not least, anyone know of a source for HD valve springs for 1.9TD's? IIRC you could use 1.8 8v HD springs on a 1.6, not sure about the 1.9.
Thanks guys.
Reply #1June 15, 2006, 02:44:06 pm
« Reply #1 on: June 15, 2006, 02:44:06 pm »
valve springs?  it's a hydro head
Reply #2June 15, 2006, 02:59:29 pm
935racer
« Reply #2 on: June 15, 2006, 02:59:29 pm »
Valve springs are all gonna fit, the stock diesel ones and the gasser hd ones are the same. You need to find out if your 1.9td head is equipped with with 7mm (late model) or 8mm (early models up to around 95) valves. The 1.6 injectors fit fine in the 1.9 head, they are just shorter, just use 1.6 injector lines and you are set. I carry full seal kits for both types of 1.9 heads. And if you do have 8mm valves and would like to switch all you have to do is get all new valves, guides and seals, lifters, this alone is good for about 8-10% increase in flow. All the 8mm 1.9 heads I rebuild get converted to 7mm.
Reply #3June 16, 2006, 04:04:58 am
  • 656
« Reply #3 on: June 16, 2006, 04:04:58 am »
Quote from: 935racer
Sweet thanks a lot! 8-10% increase in flow is very good, combine that with P&P and you get plenty more airflow.
PM me with your price on both types of head, I'll buy one if I get the head. Can the numbers casted on the head tell which type it is?
Reply #4June 16, 2006, 04:10:59 am
  • 656
« Reply #4 on: June 16, 2006, 04:10:59 am »
Quote from: Trev0rbr
Hydro heads have springs too. That's how the valves stay closed.
Reply #5June 16, 2006, 07:21:38 am
« Reply #5 on: June 16, 2006, 07:21:38 am »
Quote from: Black Smokin' Diesel
and they just use hydraulic pressure to open them. :)
Reply #6June 16, 2006, 08:25:01 am
greggearhead
  • 153
« Reply #6 on: June 16, 2006, 08:25:01 am »
Actually, they use a camshaft to open them.  They use hydraulic pressure to take up the lifter-camshaft clearance, instead of shims.
Caddy (TD Project), Caddy 1.6D, etc etc.
  Snow Performance Water-Methanol Injection
Reply #7June 16, 2006, 08:46:35 am
« Reply #7 on: June 16, 2006, 08:46:35 am »
Quote from: greggearhead
forgot about the lifters in there!
Reply #8June 16, 2006, 04:21:06 pm
935racer
« Reply #8 on: June 16, 2006, 04:21:06 pm »
A complete gasket set includes valve guide seals, intake manifold gasket, exhaust manifold gaskets, valve cover gasket, the rubber seals for the 3 bolt holes in the top of the valve cover, injector heat shields, cam seal, and the 2 o-rings for the coolant flanges on the side of the head  comes ot a grand total of $65CAD :D  If you want prices for 7mm valves, guides, lifters etc, I should  be able to get those prices up on the website this weekend.
Reply #9June 21, 2006, 06:56:15 am
  • 656
« Reply #9 on: June 21, 2006, 06:56:15 am »
Great thanks a lot. I'll contact you if I need the kit :D
