Author Topic: 1.6TD + automatic trans  (Read 3212 times)
June 09, 2006, 02:22:23 pm
zooky
  • 71
« on: June 09, 2006, 02:22:23 pm »
how would a 1.6TD (tuned) do behind say a small 2wd Toyota pickup with an OD automatic? Any idea? I've heard conflicting info about diesels and automatics. I heard they suck up too much power and that they work good together because the turbo will stay under boost while it shifts through the gears. Any thoughts?
Reply #1June 09, 2006, 03:39:35 pm
lyeinyoureye
  • 96
« Reply #1 on: June 09, 2006, 03:39:35 pm »
Well, I'm guessing your Toyota is ~2700 lbs, so moving the extra weight and going through the auto tranny might yield the same performance as a NA mk1? I was thinking doing that swap with my W40 tranny/3.73 (I think) rear end when my 22r dies (never?) and I'd probably have to used a TD just to get NA performance based on comparing the gearing and weight.
vw rabbit- d-3.89,1-3.45,2-1.75,3-1.06,4-.71 155-80-13, 2000lbs
toyota pu- d-3.73,1-3.29,2-2.04,3-1.39,4-1 195-75-14, 2700lbs
Rpm, going up a gear in 15mph increments.
vw- 2972@15,3015@30,2739@45,2446@60
toy- 2424@15,3007@30,3073@45,2948@60
Now the 22r makes ~130 ft/lbs of torque at ~3k rpm, but the 1.6l makes much less. The tdi in the dyno thread only makes ~80 ft/lbs at ~3k rpm, so using a tuned TD will probably yield the same numbers a 22r does, with a much flatter torque curve.
Reply #2June 09, 2006, 05:46:42 pm
DVST8R
  • 535
Re: 1.6TD + automatic trans
« Reply #2 on: June 09, 2006, 05:46:42 pm »
Quote from: "zooky"
Depending how tuned the 1.6 of course, but I had a 86' 2wd auto 22re toy pu, and many 1.6td's in verious states of tune, and I would say that a mildly tuned 1.6td would be just as quick as the stock 22re with better fuel economy.
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #3June 09, 2006, 07:32:13 pm
zooky
  • 71
« Reply #3 on: June 09, 2006, 07:32:13 pm »
that is what I was hoping to hear. I am rebuilding the engine now, not sure where I am putting it. The bottom end is done, stock except Gapless rings. Im going through the head now, maybe do a little port and polish. I am waiting on my turbo rebuild kit and may send my IP to Giles if it would make the truck more driveable. I will probally upgrade the injectors and add an intercooler.[/quote]
Reply #4June 09, 2006, 07:36:27 pm
DVST8R
  • 535
« Reply #4 on: June 09, 2006, 07:36:27 pm »
With all of that it will easly out pull a stock or even mid modified 2re (rv cam, header, exhaust) I think you will enjoy it. The Giles pump is really worth the money.
Reply #5June 10, 2006, 05:34:20 pm
zooky
  • 71
« Reply #5 on: June 10, 2006, 05:34:20 pm »
you think a stock 4x4 is too much with the above mentioned mods? Would a 5-speed be better? I already own a 4x4 but figured it would be too heavy (3700 lbs)
Reply #6June 10, 2006, 05:40:56 pm
DVST8R
  • 535
« Reply #6 on: June 10, 2006, 05:40:56 pm »
I think it would be just fine.
There are some things that you can do to help the shifting on that auto as well, but I can't find the link's off hand. It has to do with controling the tq converter lockup and such. In any case I wouldn't hesitate to run it.
Reply #7June 10, 2006, 06:55:28 pm
zooky
  • 71
« Reply #7 on: June 10, 2006, 06:55:28 pm »
I'd be able to handle highway speeds? Thanks for the replys, I have never driven a 1.6TD, I'm a noob
Reply #8June 11, 2006, 12:19:11 am
DVST8R
  • 535
« Reply #8 on: June 11, 2006, 12:19:11 am »
and then some! I could wrap my speedo @200km/h+ in my jetta with similar mods, so I am sure even with the added weight and drag, you would be able to drive comfortably at any hwy speeds.
