S-PAutomotive.com
Author Topic: Injection pump  (Read 5832 times)
May 12, 2004, 05:40:01 am
Dennis Froelich
  • 229
Injection pump
« on: May 12, 2004, 05:40:01 am »
Has anyone replaced the cold start o rings on their injection pumps? I don't want to have to take it to a shop to have it done.
I want to learn how to do it myself.
Thanks again :mrgreen:
79 Golf GTD
96 Golf GTD(TDI)
Reply #1May 12, 2004, 08:01:36 am
BlackTieTD
  • 1512
Injection pump
« Reply #1 on: May 12, 2004, 08:01:36 am »
make sure whatever you do, you keep everything immaculately clean.
sorry i can't offer specific advice. just be careful about dirt.
Reply #2May 12, 2004, 04:36:31 pm
Dennis Froelich
  • 229
Injection pump
« Reply #2 on: May 12, 2004, 04:36:31 pm »
This should be interesting. Definately will be a clean work area. Plan on cleaning it before I take it off.
79 Golf GTD
96 Golf GTD(TDI)
Reply #3May 12, 2004, 06:14:38 pm
DieselsRcool
  • 152
Injection pump
« Reply #3 on: May 12, 2004, 06:14:38 pm »
It's about a 2 min job if you have the pump off. 2 screws, take the arm assy off, replace the o-ring, put the arm assy back on, 2 screws back in, done! Even I can do this one. :)
Reply #4May 13, 2004, 04:45:24 am
Dennis Froelich
  • 229
Injection pump
« Reply #4 on: May 13, 2004, 04:45:24 am »
OK. Thanks for your input.  :)
79 Golf GTD
96 Golf GTD(TDI)
Reply #5May 13, 2004, 10:18:44 am
fspGTD
  • 1529
Injection pump
« Reply #5 on: May 13, 2004, 10:18:44 am »
I know at least for the front cover of the timing advance, you need a funky torx-type tool to fit into the bolt heads.  Not sure if you need those for the rear cover where the timing advance lever is or not.  But anyway if it's got the torx, don't use an Allen as the bolts can be corroded in and it takes a lot of force required to break them loose, which will run a high risk of stripping those torx bolts.
Jake Russell
Reply #6May 13, 2004, 03:35:50 pm
Dennis Froelich
  • 229
Injection pump
« Reply #6 on: May 13, 2004, 03:35:50 pm »
Quote from: "fspGTD"
Thank you very much for that info. I have quite a few tools, including alot of VW special tools. I was a VW and Mazda tech for a few years. :mrgreen:
79 Golf GTD
96 Golf GTD(TDI)
Fixmyvw.com
