Author Topic: 1.6td upgrade queries?  (Read 4076 times)
May 29, 2006, 09:00:23 am
Wills
  • 27
« on: May 29, 2006, 09:00:23 am »
Hi Im new, I have a 89 Caddy 1.6 na diesel but I want more power, ive just picked up an 89 passat cl with a 1.6 td motor in and want to know how easily the new motor will fit, from what I gather looking around the site I need to make a manifold but not really much else, am I correct or just blind?
Reply #1May 29, 2006, 09:12:46 am
SMOKEYDUB
  • 630
« Reply #1 on: May 29, 2006, 09:12:46 am »
you shouldnt have to make a manifold it should bolt in with all of the caddy brackets put on to the passat engine.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #2May 29, 2006, 01:19:23 pm
Wills
  • 27
« Reply #2 on: May 29, 2006, 01:19:23 pm »
So other than that it should be just a case of taking out the old and bolting in the new? Its my daily you see and I can't really afford to have it off the road for long, Basically I should be able to remove the old Na unit and the TD will slot straight in wireing and cooling, driveshafts, engine mounts, nothing as far as anyone knows.
Reply #3May 29, 2006, 02:10:07 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #3 on: May 29, 2006, 02:10:07 pm »
How is the engine mounted in the passat? If it is mounted longitudinally, you will need an exhaust manifold.
'89 Caddy? Is that based on the MKII platform?
Reply #4May 29, 2006, 02:16:51 pm
Mark(The Miser)UK
  • 1557
« Reply #4 on: May 29, 2006, 02:16:51 pm »
Wills
 That is the Passat that looks like a Skoda front...and not one of the very very very last B2 Passats(Quantums) to be registered because those have the turbo placed differently...
Mark-The-Miser-UK
Reply #5May 30, 2006, 07:14:34 am
Wills
  • 27
« Reply #5 on: May 30, 2006, 07:14:34 am »
Now thats a good question, its the first one that came out without an actual grille, I dunno how else to describe it, its ugly if thats any good, if its the wrong one, am I looking at problems?
Reply #6May 30, 2006, 07:45:32 am
HP
  • 225
« Reply #6 on: May 30, 2006, 07:45:32 am »
If it's this one  :arrow:
...it has a transverse engine alignment and isn't ugly..
Reply #7May 30, 2006, 12:49:05 pm
Mark(The Miser)UK
  • 1557
« Reply #7 on: May 30, 2006, 12:49:05 pm »
Quote from: Wills
Nah  you're OK
Did I say Skoda? Or did I mean DAF  :lol:
It's just a variation on the Golf setup so it's an easy swap... :D
I never said ugly... :wink:
I wonder if someone stuck a grill on the front it would improve it?
Mark-The-Miser-UK
Reply #8May 30, 2006, 12:51:56 pm
Mark(The Miser)UK
  • 1557
« Reply #8 on: May 30, 2006, 12:51:56 pm »
Quote from: HP
That's a nice example; but the mars red or polar white ones were  definitely ugly :wink:
Mark-The-Miser-UK
Reply #9May 30, 2006, 03:28:05 pm
Wills
  • 27
« Reply #9 on: May 30, 2006, 03:28:05 pm »
Mars pink! Yeah thats the one, I only paid £45 for it and its got a brand new battery and Bosch Alternator, but it desperatly needs new glow plugs, so, I got the easy to fit one? Does anyone know what power the engine in this produces, its sounds loads better than the one Im running.
Reply #10May 30, 2006, 04:05:32 pm
HP
  • 225
« Reply #10 on: May 30, 2006, 04:05:32 pm »
59KW.
Reply #11May 30, 2006, 07:52:36 pm
Mark(The Miser)UK
  • 1557
« Reply #11 on: May 30, 2006, 07:52:36 pm »
Code: [Select]
They must be painted with red book ink.
 :shock: Unfortunately the swap with my Quantae is more difficult unless I care to drop it into an Audi TT :shock:
Mark-The-Miser-UK
