Author Topic: quick question > 1.9TD and VNTs  (Read 7124 times)
Reply #15May 30, 2006, 10:15:46 am
Benjamin
  • 485
« Reply #15 on: May 30, 2006, 10:15:46 am »
yeah, its realy a gr8 movie, no lag at all  :D  8)
how much hp are you making? if you got a 0-100 movie ore something, just post it.
Anyway, ontopic, i just don't see the advantige of youre VNT controller.
Greetz, Benjamin
Must make +250hp
Reply #16May 30, 2006, 02:35:41 pm
Tintin
  • 1279
« Reply #16 on: May 30, 2006, 02:35:41 pm »
Quote from: "Benjamin"
Greetz, Benjamin
For the power, no advantage....
To reach 15-20 or 25 PSI, no advantage.....
I made this system right so that the vannes opens when I release gas,  And the boost control much better has different cruising speeds.
look at this post, you will understand better why I made this system.
http://vwdiesel.net/phpBB/viewtopic.php?t=1306&postdays=0&postorder=asc&start=0
Reply #17May 30, 2006, 10:12:13 pm
ezekiel
  • 147
« Reply #17 on: May 30, 2006, 10:12:13 pm »
okay, so if I decide against the VNT-17/VNT-20 (20 is difficult to fit, 17'll still do 25psi, no?) what would be my other options to net 25psi.  I'm just trying to compare costs at the moment.  New exhaust manifold/turbo VNT-17 is $950 from KermaTDI.  How much would getting new parts (manifold turbo wastegate if not internally gated) get me?  I figured I'd be looking at over $950 already, so in and of itself it seems the VNT-17 is better money wise, for me atleast.  I'm going to try just outright running it on an Apex'i AVC-R, which allows for RPM and gear based boost control.
Reply #18May 31, 2006, 04:25:54 am
Benjamin
  • 485
« Reply #18 on: May 31, 2006, 04:25:54 am »
Quote from: ezekiel
turbopressure is not evrithing, there is also flow.
a VNT17 will need more boost than a VNT20 to give the same air.
VAG got a GT1749v and a GT1749VB, the last one is for the 150hp models, wich will give more air (correct me if i'm wrong).
You can find T2 flanges (a T2,T25,T28, GT20, ... and even some T3 i tought will fit) on some vw TD's wich use a T2. than buy a gt20v will be much cheaper than this 950UD/CAD.
I got a good VNT20 for sale.
Like you can see, a VNT20 even on a 1.6 give no lag when you got the right fuel adjustment.
On the 1.9TDI's (150hp stock) they go with stock turbo to a good 200hp, so i think its good enough though
Greetz, Benjamin
Must make +250hp
