Author Topic: bigger injectors  (Read 3015 times)
May 25, 2006, 08:29:58 am
Benjamin
  • 485
bigger injectors
« on: May 25, 2006, 08:29:58 am »
i don't know ore there is allready a know how of this.
Do all the injectorshousings are the same from Bosch? exchangeable?
i was searching for bigger injectors.
i didn't found aftermarket injectors, so we can search the best from just stock cars.
about the openingpressure, this is regulable, so that will not be the problem.
Ore are there other problems to?
the advantages of a optimal injector use (especially not overfeuling) are less EGT's, better feul economy
Greetz, Benjamin
EDIT:
i found Lancia wich i thought they use Bosch injectors on a 2.5td 4cylinder, it makes 118hp/245Nm, thats about 29,5hp/cilinder.
there is even a alfa (not the same engine!!), 2,5td 4cilinder, 125hp/294nm, thats a little more flow. about 31,25hp flowing through injector
Must make +250hp
Reply #1May 25, 2006, 11:39:13 am
Audi80
bigger injectors
« Reply #1 on: May 25, 2006, 11:39:13 am »
There is no need for bigger injectors for horsepower. I know a 1,6 Caddy which has 250+hp with stock 1,6TD injectors
Reply #2May 25, 2006, 01:13:02 pm
HP
  • 225
bigger injectors
« Reply #2 on: May 25, 2006, 01:13:02 pm »
And which inj pump does it have?
Reply #3May 25, 2006, 01:18:36 pm
Audi80
bigger injectors
« Reply #3 on: May 25, 2006, 01:18:36 pm »
1,6TD pump with 12mm plunger
Reply #4May 25, 2006, 01:55:05 pm
Benjamin
  • 485
bigger injectors
« Reply #4 on: May 25, 2006, 01:55:05 pm »
thats 3x as much as stock.
So there is no need for bigger injectors at all?!! Just always take the 1.6td injectors...  8)
Why are there so many different injectors :?:
@Audi80: tell us more about "how get 250+hp out of a 1.6td"  :D
Greetz, Benjamin
Must make +250hp
Reply #5May 25, 2006, 02:26:23 pm
Audi80
bigger injectors
« Reply #5 on: May 25, 2006, 02:26:23 pm »
The injectors are not the first restrictive part in idi engine. Those 500+hp Mercedes uses stock 300D injectors. Did Malone try these?
Quote from: Benjamin
@Audi80: tell us more about "how get 250+hp out of a 1.6td" Very Happy
You will need a lot of fuel, and lots of cool air going through the engine ;)
That Caddy has a Mitsubishi turbo ~@50psi, 3" exhaust, big intercooler, ported head and custom manifolds.
Reply #6May 25, 2006, 03:48:40 pm
935racer
bigger injectors
« Reply #6 on: May 25, 2006, 03:48:40 pm »
Yeah I put 300d nozzles in malones engine one night, actually the complete injectors, they were pretty old and used but they still sprayed fine when I put them on the pop tester. They were set at 135 bar, they didnt make a huge difference but they did have more topend. I bought some brand new 300d nozzles and installed them in another customers car about a month ago, and the brand new ones at 155 bar were awesome! little more down low and quite a bit more fuel up top is how it felt, the car was a 1.9td mk3 golf, fairly stock, just one of my downpipes and a giles pump. I definately think there are good power gains to be made from having bigger inejctors, but the Ip and airflow in and out of the engine are gonan be the bigger issues necessary to address.
