Author Topic: Dynoing the td next sat, suggestions?  (Read 2667 times)
May 17, 2006, 08:59:52 pm
Cheesetoast
  • 285
« on: May 17, 2006, 08:59:52 pm »
it's a 93 td idi, what gear should i dyno it in and would cetane booster make a difference in power?  Running 5% biodiesel in it right now
Reply #1May 18, 2006, 12:20:42 am
2mAn
Re: Dynoing the td next sat, suggestions?
« Reply #1 on: May 18, 2006, 12:20:42 am »
Quote from: Cheesetoast
4th is usually the most accurate gear to know eactly what its putting to the ground. i also think the power output would be higher with no biodiesel
Reply #2May 18, 2006, 02:04:13 am
TDIMeister
  • 284
« Reply #2 on: May 18, 2006, 02:04:13 am »
5% bio will not make any noticeable difference.
Where are you located, cheesetoast?  There is a Diesel dyno day in London, ON in early June posted in the GTG section.  Your shaw.ca domain suggests you are in Canada (duh!  :oops: )
Reply #3May 18, 2006, 02:17:14 pm
Cheesetoast
  • 285
« Reply #3 on: May 18, 2006, 02:17:14 pm »
i'm in vancouver, bc, dyno date is next sat here.
Quote from: TDIMeister
Reply #4May 18, 2006, 06:38:27 pm
dennis m king
  • 36
« Reply #4 on: May 18, 2006, 06:38:27 pm »
from dynoing cycles a lot the computer knows the rate of acceleration on the drumb and how much torque vs acceleration it is seeing. mostlikely be close in all the gears but a td should work better in the taller ones.
86td jetta
96 dodge td ram
86 gpz750 turbo
i like turbos
