Author Topic: Fueling question (slightly different)  (Read 2577 times)
May 15, 2006, 06:29:38 pm
zagarus
  • 619
« on: May 15, 2006, 06:29:38 pm »
well i increased my fueling a bit more today to the point where i pretty much can't use my advance timing choke.  My idle sits at around 1150-1250 when warm, and thats with it adjusted to be as low as possible.  Now im just worried cause it takes my car a bit to start up without the choke, and i dont want that.  Any ideas how i can get it to be functional again?
Reply #1January 27, 2009, 10:08:10 pm
lildevil
  • 49
« Reply #1 on: January 27, 2009, 10:08:10 pm »
did you ever fix that? Mine idles just like yours, I turned my fuel down, what wonders that did, now she spins tires like nothing
Delmonte...Some Serious *** My Friend
Reply #2January 27, 2009, 11:42:42 pm
zagarus
  • 619
« Reply #2 on: January 27, 2009, 11:42:42 pm »
i bought a Giles pump, solved every fueling issue possible  :lol:
Reply #3January 28, 2009, 12:52:33 am
Clintwalker85
  • 91
« Reply #3 on: January 28, 2009, 12:52:33 am »
what did the pump cost ya
Reply #4January 28, 2009, 04:37:35 am
dillenger1
  • 777
« Reply #4 on: January 28, 2009, 04:37:35 am »
You can bring it down further by relocating the throttle lever on the splined shaft.Mark your spot and rotate clockwise.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #5January 28, 2009, 04:45:55 am
Dirtrag2
  • 298
« Reply #5 on: January 28, 2009, 04:45:55 am »
on a mk3 ( not sure about mk2 )  you can adjust the throttle cable via plastic adjustment thingy on the pump. this allows for more negative travel in cable so you can set the residual fuel pin ( the bolt behind pump that the throttle lever rests on ) to a lower setting.
this solved my high idle and the advance lever still worked perfect.
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
