Author Topic: 1.7 Diesel pistons  (Read 9865 times)
Reply #15May 12, 2006, 05:05:41 pm
935racer
1.7 Diesel pistons
« Reply #15 on: May 12, 2006, 05:05:41 pm »
Just made some calls, I cant find any sources for these pistons on this side of the pond. Anyone know where I coudl find a set? I would love to see if the pin height and pin size is the same as the 1.6, and if it isn't I'd like to know what the stroke, and crank journal size is along with rod length.
Reply #16May 13, 2006, 07:09:36 am
scopefrfd
  • 289
1.7 Diesel pistons
« Reply #16 on: May 13, 2006, 07:09:36 am »
What  I like about the pistons...is the 5-7extra hp on a n/a engine almost stock turbo power.  That's huge on a 1.6 n/a engine.  I would assume it's good for atleast an extra 7.5hp-15hp on a 1.6 td at the same boost levels.  In a lighter A1 or A2 chassis the engine should be very lively.  What's killing the deal is the dollar is going down daily vs the euro.  A dollar is worth less than $.80 as of friday.
Reply #17May 13, 2006, 09:00:23 am
Baxter
1.7 Diesel pistons
« Reply #17 on: May 13, 2006, 09:00:23 am »
You don't see many KY's out there to be honest, but yep it's true they are out there somewhere.
Im fairly sure they used the 1.7 in something else, Iltis I think but not 100%, quite sure the 1.7D isn't unique to the T3.
It is just a bigger 1.6, same manifolds etc, same piss poor performance!
Stuff from my website here...
http://194.242.159.246/brickyard/info/enginedata/dsl/KYdata.htm
Reply #18May 13, 2006, 09:07:18 am
935racer
1.7 Diesel pistons
« Reply #18 on: May 13, 2006, 09:07:18 am »
Ok so they do have the same stroke, but the rods still could be completly unique to that engine and I would suspect they are. I am gonna go talk to this guy again about this 1.7, he said it was marine stuff he used cause his boss was into boats or something....
Reply #19May 13, 2006, 09:07:37 am
Audi80
1.7 Diesel pistons
« Reply #19 on: May 13, 2006, 09:07:37 am »
1,7 uses the same crank and connecting rods
pic
Reply #20May 13, 2006, 12:49:57 pm
scopefrfd
  • 289
1.7 Diesel pistons
« Reply #20 on: May 13, 2006, 12:49:57 pm »
Everything is the same as the 1.6D engines, except for the pistons and HG.  I'm definitely going to buy a set and try them out.
Reply #21May 13, 2006, 01:57:58 pm
tylernt
  • 344
1.7 Diesel pistons
« Reply #21 on: May 13, 2006, 01:57:58 pm »
Quote from: scopefrfd
Right on. You could be the first to start a popular trend, if they work.  8)
Reply #22May 13, 2006, 05:11:03 pm
Baxter
1.7 Diesel pistons
« Reply #22 on: May 13, 2006, 05:11:03 pm »
Im fairly sure that back in the day Simon Coopers "Sooty" golf drag car was a 1.7 TD, sure someone will correct me though.
Reply #23May 14, 2006, 07:14:57 pm
DieselsRcool
  • 152
1.7 Diesel pistons
« Reply #23 on: May 14, 2006, 07:14:57 pm »
Sounds like a good way to save a bored out hard to find 1.6 TD block here in the States. Notching them for squirters is doable with an end mill.
I'll take a set for stock.  :D
Reply #24May 16, 2006, 07:34:33 pm
vph
  • 41
1.7 Diesel pistons
« Reply #24 on: May 16, 2006, 07:34:33 pm »
Look at the bottom of this page... Do you all suppose these are the pistons?
http://www.importperformanceparts.net/imports/flat_hyperpiston.html
'60 Bug Ragtop, 901 5spd
'93 Honda Civic
Reply #25May 17, 2006, 05:39:54 am
1.7 Diesel pistons
« Reply #25 on: May 17, 2006, 05:39:54 am »
Nope, wrong engine codes, those are gassers.
84 Scirocco 8v
00 Camaro L36 M49
Reply #26June 14, 2006, 07:58:54 pm
wolfgang
  • 1
    • http://www.westonindustries.net
1.7 Diesel pistons
« Reply #26 on: June 14, 2006, 07:58:54 pm »
one thing I noticed is that two other VW diesels have the same 79.5mm dimentions. the 90-160 hp 1.9 TDI 4 banger made in mexico, and the 70-90 hp 1.4 TDI 3 banger for the A2
The 1.4 has the specs:
Configuration
    Diesel 1422 cc (86 in³) inline three cylinder
Block
    bore * stroke 79.5 * 95.5, grey cast iron
Head
    2 valves, overhead camshaft, 18 to 19.5 compression ratio
Output
    51 kW (70 hp) @ 4000 rpm, 155 N·m between 1600 and 2800 rpm
    55 kW (75 hp) @ 4000 rpm, 195 N·m (144 ft·lbf) @ 2200 rpm
    59 kW (80 hp) @ 4000 rpm, 195 N·m @ 2200 rpm
    66 kW (90 hp) @ 4000 rpm, 230 N·m from 1900 to 2300 rpm
Applications
    Audi A2, VW Lupo, VW Polo, SEAT Arosa, SEAT Ibiza, SEAT Córdoba, Škoda Fabia
These are both TDI engines and we have an IDI setup.. So I'm asking, forgive the noob, but what is the difference between the IDI pistons and the TDI pistons?
Reply #27June 14, 2006, 08:07:50 pm
tylernt
  • 344
1.7 Diesel pistons
« Reply #27 on: June 14, 2006, 08:07:50 pm »
The IDI piston has a fairly flat top with two shallow "cloverleaf" indentations, as the combustion chamber is in the cylinder head. The TDI piston has a great big bucket hollowed out of the middle, which serves as the combustion chamber. The bucket also has a spike on the bottom and a little lip to encourage a donut-shaped swirl.
Reply #28June 14, 2006, 08:38:11 pm
Kudagra
  • 738
    • www.no-coast.com
1.7 Diesel pistons
« Reply #28 on: June 14, 2006, 08:38:11 pm »
TDI  pistons usually (if not always) have a cup in them while IDIs are flat.
One thing I did notice is the pistons on a Kubota v1902 IDI  engines look the same  from the top other then alot larger bore. Ill check the other measurements on them just for chuckles.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
