Author Topic: how far do you go on a tank?  (Read 18885 times)
Reply #15May 15, 2006, 03:16:09 pm
Mark(The Miser)UK
  • 1557
« Reply #15 on: May 15, 2006, 03:16:09 pm »
Quote from: zagarus
what you guys say to be the best additive to use, my last tank i used STP injector cleaner and fuel treatment, but didn't notice to much,  I've been averaging 37 MPG the last month and a bit. I want to go further on a tank
 :idea:
Code: [Select]
Add a litre of Canola..[/color] :idea:
Mark-The-Miser-UK
Reply #16May 15, 2006, 03:20:14 pm
TD_vento
  • 39
« Reply #16 on: May 15, 2006, 03:20:14 pm »
Quote from: Mark(The Miser)UK
Quote from: TD_vento
i  than mine :x
[/color][/size]
Blimey 400 miles/ tank?
Solutions/reasons
1) Your rebuild mechanics swapped a gasser in whilst your head was turned.
2) You're driving a tank with a VW badge.
3) You have a limited edition drug smuggler's fuel tank.
4) You drive like Jake round a track.
..Ok jokeing aside
Is anything binding?
Do you have pre-rebuild mileage?
Smokin' ?
Fokin funny bastard, was cracking  :lol:
MIlage now is 142k hmm im not really sure what the hell is wrong with teh bastard, it seems to be ok on power, has around 9-10 psi, tends to smoke when beating it and I do have a heavy foot I must say but still :?
Reply #17May 15, 2006, 08:17:12 pm
fspGTD
  • 1529
« Reply #17 on: May 15, 2006, 08:17:12 pm »
Moved to General.  IDI Engine is for performance enhancement discussion only.
Jake Russell
Reply #18May 15, 2006, 11:36:13 pm
maddog007
  • 34
« Reply #18 on: May 15, 2006, 11:36:13 pm »
edit
Reply #19May 19, 2006, 09:28:10 pm
Traktor
  • 26
« Reply #19 on: May 19, 2006, 09:28:10 pm »
I get 800km city and 1000+  highway. I once went from Calgary to Nanaimo on one tank of fuel, 1100km, and that's over the Rockies.
'86 Golf 1.6l na diesel (hit & run victim)
'90 Golf GTI 1.8 8v SOLD
'84 1.6 td Rabbit
Reply #20June 20, 2006, 09:48:50 am
RAMMSTEIN
  • 331
« Reply #20 on: June 20, 2006, 09:48:50 am »
I got 1179.1 km on my last tank with my 1992 Jetta (1985 1.6D in it).
The car is not aligned and I don't have a cruise control yet.
My guess is that I'll be able to see 1400 ++++ km per tank eventually.
BTW, the tank capacity on A2's is exactly 59.9 litres.
I got to my favorite station and when the jetta saw the pump, she died. :oops:
5 seconds of cranking and I was back on the road.
For this tank, 350 km before the gauge gets off the full mark and 500 km at 3/4. :D
Not as economical as my B4 passat, but a fun little car nonetheless. :)
Rammstein
In abscence of light, darkness prevails.
Reply #21June 27, 2006, 08:30:27 pm
moosiah
  • 106
milage
« Reply #21 on: June 27, 2006, 08:30:27 pm »
So my Rabbit  got a little over 50mpg coming home over Donner Pass(I was in a hurry!)  from central Nevada sunday night ,,,,240000 miles not bad...  and this w my 14x6 24 inch dirt road tires to boot too!  I'm very  :D
I do use the white can Power service goop too, but not on this trip, otherwise I be up around 54- 55....... :)
'81 Frankenbunny: part rabbit, sirroco, golf ,caddy cabrio ,jedda and ! ford teimpo! w a little more Audi and soon some Peogeot too!!!!
Reply #22June 29, 2006, 06:58:24 am
RAMMSTEIN
  • 331
« Reply #22 on: June 29, 2006, 06:58:24 am »
I got 4.39 l/100 km on my second to last tank, best so far.
I went in hilly terrain and got 5.26 (filled up monday).
Here's a bad combinaison: 10% hills and 1.6D NA... :?
I had to go uphill in 3rd at 4500 rpm... :cry:
Rammstein
Reply #23July 06, 2006, 04:50:30 pm
Laurentian
« Reply #23 on: July 06, 2006, 04:50:30 pm »
Yikes, what's up with my 1.6D??
I typically have been getting only 750 km's per tank for past couple years, drive around 120km's / hour.
Original everything, must be my leaking pump head and injectors.
I once did get 1000k out of a tank 10 years ago but drove under 100 all week.
Hugh
Reply #24July 07, 2006, 12:00:59 pm
RAMMSTEIN
  • 331
« Reply #24 on: July 07, 2006, 12:00:59 pm »
Drive slower and change you pump's seals, you should get better mileage then. :wink:
Rammstein
Reply #25July 07, 2006, 06:31:17 pm
mainer
  • 126
« Reply #25 on: July 07, 2006, 06:31:17 pm »
I've got 700 and it's just below a half tank. Gotta love the waste veggie oil.
Coop
_________________
Caodaism Forum
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
Reply #26July 09, 2006, 09:33:56 am
RAMMSTEIN
  • 331
« Reply #26 on: July 09, 2006, 09:33:56 am »
For this tank I got to 820 before the needle gets off the white half way mark. :D
Will fill up today and report back (1111 km so far). :twisted:
Rammstein
