Author Topic: MK3 GTD  (Read 10832 times)
Reply #15April 25, 2006, 02:32:20 pm
Otis2
  • 191
MK3 GTD
« Reply #15 on: April 25, 2006, 02:32:20 pm »
Envy - have a read through this recent thread in the "Troubleshooting" section:
http://www.vwdiesel.net/phpBB/viewtopic.php?t=3614&start=0
Reply #16May 19, 2006, 01:52:52 am
envy
  • 19
MK3 GTD
« Reply #16 on: May 19, 2006, 01:52:52 am »
Now I've workod with my pump! And golf is getting faster! What I get! I undersood that new cluch is necessary :) So now I think abou the intercooler! What could you tell! Can I put one from TDI or its better to find one from Mk2 GTD???
TDI PD ~150HP & 380Nm
Reply #17May 19, 2006, 10:56:44 am
Benjamin
  • 485
MK3 GTD
« Reply #17 on: May 19, 2006, 10:56:44 am »
when do you know the injectors/nozles are getting to little when feuling up??????? Can you measure this on a IDI, how do can you do this? (not enginespecifik please)
Greetz, Benjamin
Must make +250hp
Reply #18May 21, 2006, 02:53:08 pm
Benjamin
  • 485
MK3 GTD
« Reply #18 on: May 21, 2006, 02:53:08 pm »
Quote from: Benjamin
Someone who can get me this exlained? :roll:
tnx
Greetz, Benjamin
Must make +250hp
Reply #19May 22, 2006, 09:30:51 am
Benjamin
  • 485
MK3 GTD
« Reply #19 on: May 22, 2006, 09:30:51 am »
yes, i got a EGT meter, but the EGT goes up when the feul goes up, when there is more air, the egt's lower.
But how can i know that the injectors are to little? i'm busy with my 1.9td (non vw) i got 11mm plunjer, planning governermod, gt20v turbo, ... so how do i know my injectors are to little?
ore is there a link between EGT and to little injectors?
Greetz, Benjamin
Must make +250hp
Reply #20May 22, 2006, 10:19:32 pm
TDForNow
  • 131
MK3 GTD
« Reply #20 on: May 22, 2006, 10:19:32 pm »
My understanding is, small (overfueled) injectors would show high egt's because though, they're shooting more fuel, it's occuring with a longer duration to do so and with more timing advance to compensate for this. Bigger injectors can deliver the demanded quantity of fuel in a shorter, better timed event, helping to keep egt's down as long as there is enough air in there as well.
Alain
'85 Quantum 1.6TD
'04 Passat 2.0 8vTDI
Reply #21May 24, 2006, 10:34:36 pm
envy
  • 19
MK3 GTD
« Reply #21 on: May 24, 2006, 10:34:36 pm »
Hi again!
So nobody has answered on my quastion about IC!  :roll:
Yesterday I bought GTD nozzles and today they will be fitted! :D But the mech told me that 150bar are necessary, in forum I read smth about 155 and 180 bar? how is it??? :dontknow:
I and more! Mech also told me that I have different turbo than others AAZ has, could someone posr pics of turbo's available on AAZ!
Reply #22May 24, 2006, 11:07:02 pm
Wingaman
  • 7363
    • http://www.dmfdiesel.com
MK3 GTD
« Reply #22 on: May 24, 2006, 11:07:02 pm »
Where are you from ?
If you have an AAZ, i think your in us or canada. This engine already have a turbo.
If you speak french, go in the "Moteur a injection indirecte" in the french section of this forum.
371-B, Ch. Ste-Marie
Ste-Marthe QC J0P 1W0
Reply #23May 25, 2006, 12:41:44 am
Benjamin
  • 485
MK3 GTD
« Reply #23 on: May 25, 2006, 12:41:44 am »
about the nozzle's, i know you can adjust the pressure if you place plates under the spring, so you can make higher pressure, but i though, the pump got his limits  :!:
Greetz, Benjamin
Must make +250hp
Reply #24May 25, 2006, 06:25:49 am
envy
  • 19
MK3 GTD
« Reply #24 on: May 25, 2006, 06:25:49 am »
Quote from: Wingaman
:D I am from Latvia, near the Baltic see! ;)
of course I have turbo, but it is different from that my friends have! Also my car is faster then theirs! ;)
Therefore I want to now, what turbo is it and how to higher pressure! :)
Reply #25May 25, 2006, 04:05:52 pm
935racer
MK3 GTD
« Reply #25 on: May 25, 2006, 04:05:52 pm »
There were 4 turbos available for the 1.9td AAZ engine code. The ko3, the garrett t2 and pretty much the same one an airesearch t2, and the kkk k14. All of them are way to small for a 1.9 engine, the t2's and the k14, would be better suited for a 1000-1500cc engine, the ko3 is even smaller and would be good for something like a snowmobile :lol:  Moral of the story is get a turbo from a 1.6td a garrett t3 or a kkk k24 than you can make some decent boost without creating excessive EGT's and exhaust backpressure.
Also 155 -165 bar seems to work pretty good for tuned td's.
Reply #26May 26, 2006, 02:26:29 am
Wingaman
  • 7363
MK3 GTD
« Reply #26 on: May 26, 2006, 02:26:29 am »
I agree, but please go to your profile and set your location !
It's an inportant information for us, and a good things if u need help.
Some one near you can help you.
Like if your said your engine consump oil, I will say take the car to my home and I will check it.  :roll:  I'm from canada, and soposed to be, your from france ....
There whant I have to say :)
Reply #27May 26, 2006, 02:30:10 am
Wingaman
  • 7363
MK3 GTD
« Reply #27 on: May 26, 2006, 02:30:10 am »
Suposed to be a K14 or a T2 from your engine year.
Boot can boost 1 bar (14.7psi) without problem. Above that you can with an intercooler.
Reply #28May 26, 2006, 05:59:21 am
envy
  • 19
MK3 GTD
« Reply #28 on: May 26, 2006, 05:59:21 am »
So nozzles are fitted :D
There is much more smoke :D But I'm not sure that there is pretty much difference  :roll:
Maybe near the red line car is faster  :twisted:
And one more quastion today... How can I know, what turbo is it?? Is it written anywhere on it???
So, next step I'll do - throw out the catalysor!  8)
I got the IC from FIAT TEMPRA, now I have to think about fitting it! :)
Reply #29May 26, 2006, 09:18:46 am
Benjamin
  • 485
MK3 GTD
« Reply #29 on: May 26, 2006, 09:18:46 am »
IF this is the same as the Delta one, it will crack on HIGH boost becouse of the plastik caps.
Greetz, Benjamin
Must make +250hp
