Author Topic: 1.6D ---> 1.6TDI ?!?!  (Read 7823 times)
April 25, 2006, 06:39:03 am
HP
  • 225
« on: April 25, 2006, 06:39:03 am »
Hello guys. I must admit I havn't done much research on this matter  :oops: but just out for curiosity, I would like to ask you if do u think it's possible to convert a 1.6D block to a TDI motor.
i.e. you'd take a 1.6D bare block and do all the necessary adaptations (head, injection, electronics,....) and then you would have a 1.6TDI!!!  :D
Would that crazy conversion be possible in any way :?:  :!:
Reply #1April 25, 2006, 07:06:06 am
Justin
  • 455
« Reply #1 on: April 25, 2006, 07:06:06 am »
it would require custom pistons, doable, but I am not sure if there is enough room between the top of the pistons and the stock pin location, it maybe needed to get shorter con rods and then custom pistons. basically you need a piston  that has the same shape as the 1.9 TDI pistons and thensize the dish in the piston to the same cc as your old prechamber then it should work. I have thought about it since I have a TDI head setting around as well as a pump and just need the controler and a camshaft, or use the existing pump TDI pump to build a mechanical pump
Later
Justin
www.archeryprostaffmi.com
Reply #2April 25, 2006, 08:15:52 am
  • 1156
    • Malone Tuning Ltd.
« Reply #2 on: April 25, 2006, 08:15:52 am »
The simplest solution AFAIK is to bore the 1.6 block for OEM 1.9 TDI pistons and get custom conrods.
To have a machine shop make the correct conrod dimensions, I guess you'll need to supply a 1.6 conrod, a 1.6 piston (to measure distance between wrist pin and piston deck if there's a difference), and a 1.9 TDI piston.
The 1.6 block should be 1986.5 or newer (that came with hydraulic lifters). Why cut corners with a solid block if you're doing the TDI conversion? Hyd 1.6 TD blocks with badly scored cylinder walls are cheap.
No need for electronics. Keep your current 1.6 electronics and use a mechanical pump. More power potential / easier tuning that way.
I have a 1.6 with 1.9L AAZ pistons planned but I do have a spare 1.9TDI head and I thought of getting 1.9 TDI pistons instead.. but I'll stick with IDI for a while to see how much power we can get out of it.
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #3April 25, 2006, 08:36:45 am
Justin
  • 455
« Reply #3 on: April 25, 2006, 08:36:45 am »
Malone,
you are saying that you would feel comfotable with the over bore of that much? to stuff in 1.9 pistons in a 1.6 block?
sounds interesting and like a fun project, now i need to see if work has any pistons laying around and what the con rod length is
Reply #4April 25, 2006, 08:40:45 am
HP
  • 225
« Reply #4 on: April 25, 2006, 08:40:45 am »
So, it wouldn't be possible to keep it 1588cc and doing all the other TDI conversions?
And as for keeping the mechanical IP, the injectors would be from a TDI or from an IDI :?:  :!:  IDI injectors, right?
Reply #5April 25, 2006, 11:36:12 am
  • 1156
« Reply #5 on: April 25, 2006, 11:36:12 am »
Justin: I'm not 100% sure if there will be cylinder deformity or cracking from overboring that much. I will find out. Subtract the 1.6L block's original wall thickness by ~3.0mm between cylinders. The diameter difference between the max. overbore OEM 1.6L piston (0.040") and the stock OEM 1.9L piston is 1.984mm.
HP: 1.9 pistons in a 1.6 block and retaining the 1.6's 86.5mm [crank] stroke should result in ~1.7L displacement. If you absolutely want a little less displacement than that then use a crank from a 1.5L.
Assuming that you don't want 1.9L pistons: Do you realize the complexity of TDI pistons? It will be very costly to reproduce them. However, you could possibly use pistons from a 1.2L PD TDI. They have a ~76.5mm bore that will slide in your 1.6L block nicely. However, the 1.2L TDI has three cylinders so you'd have to source two of these engines to get at least four used pistons.. or buy new ($$$).
Yes, you can use PD TDI pistons in a VE TDI setup. Someone has already done it with no adverse effects (and ~220bhp). I know very little about 1.2 TDIs though.
It's still likely easier to use NA spec 1.9L (79.5mm) TDI pistons and finding a US-based machinist that can make custom rods.
Use TDI injectors. The TDI injectors have multiple holes whereas the IDI injector is pintle style with one hole pointing straight down. The TDI injectors (style and placement) and pistons are what really sets them apart from IDIs. The fuel ports at the very top of the IDI and TDI injectors are the same for the metal fuel lines, so you may be able to connect an IDI fuel injector pump to your TDI injectors with minimal or no modifications to the fuel lines.
The reduced stroke will improve rev capability, but do you need that in a limited RPM TDI? You'll benefit more from accepting a larger displacement. According to this document:
[IDI] combustion is faster and more complete than with DI systems, with more of the fuel being consumed even with lower amounts of air per cycle (lower A/F ratio) at the same smoke level. Since no swirl is required in the main chamber, high-efficiency directed intake ports can be used instead of the helical ports employed by DI engines, and more air is processed to provide higher volumetric efficiency with smoke-limited A/F ratios of less than 20:1. The combination of higher volumetric efficiency, reduced port-pumping losses, higher engine speed and higher combustion efficiency at lower A/F ratios produce higher power; typically, 10-15% more power at the shaft for similar-displacement engines.
The TDIs are however ~10-15% more fuel efficient and that seems to be the biggest strength of DI over IDI. If this is what you're after, then by all means go for it. I'd love to see a 1.6L or 1.7L hybrid TDI :D However, considering the average cost of custom rods alone ($900 USD), you're probably better off searching for a decent used or rebuildable 1.9L TDI longblock.
Don't forget to factor in the cost of modifying a fuel injection pump for enough pressure for optimal DI.
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #6April 25, 2006, 12:31:34 pm
HP
  • 225
« Reply #6 on: April 25, 2006, 12:31:34 pm »
Thanks a load for those detailed explanations, malone.  :)  But this topic is supposed to be only a discussion on this matter (and it's being, a good one!). I'm not keen to do such an operation on my engine, therefore.
I want to keep my thing completly 1.6L IDI  :twisted:
Wouldn't have any other choice, either way. €€€....  :cry:   :roll:
