Author Topic: Effect of TD injectors in a NA engine.  (Read 2310 times)
April 24, 2006, 03:54:28 pm
Baxter
« on: April 24, 2006, 03:54:28 pm »
Wanted some GTD injectors for my T3,the ones taken out are recently rebuilt ones, TD ones, just not GTD ones.
I have a 1.6NA Caddy, just wondering if to put the 1.6TD injectors in the caddy and send the caddy ones back for the surcharge on the core.
Will there be any detremental effects of running GTD injectors in a NA truck?
The Caddy rattles from the engine of a morning, a hard rev to the limiter, followed by a could of black smoke usually clears it.
Fairly sure the noise is an injector rather than a tappet noise.
Reply #1April 24, 2006, 05:45:09 pm
« Reply #1 on: April 24, 2006, 05:45:09 pm »
i'm pretty sure it would throw the timing off because the 2 injectors pop at 2 different perssures
Reply #2April 24, 2006, 09:23:21 pm
SMOKEYDUB
  • 630
« Reply #2 on: April 24, 2006, 09:23:21 pm »
i used td injectors in my stock na without changing anything. I noticed it was quiter but thats it.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
