S-PAutomotive.com
Author Topic: 3 vbelt setup - tension locations  (Read 2730 times)
December 28, 2018, 06:31:09 pm
mstephenson
  • 47
« on: December 28, 2018, 06:31:09 pm »
How/Where do I loosen/tighten the big belt that runs from the crank/h2o pump/ac compressor?
Is it the tensioner just below the alternator? Does that work both the alt and ac?
Please say it's easy.
Thanks,
michele
Reply #1December 28, 2018, 06:37:30 pm
mstephenson
  • 47
Re: 3 vbelt setup - tension locations
« Reply #1 on: December 28, 2018, 06:37:30 pm »
Reply #2December 31, 2018, 06:55:45 pm
mstephenson
  • 47
« Reply #2 on: December 31, 2018, 06:55:45 pm »
I found all the places after I took off the alternator. And yes, it was easy. I guess I was just flummoxed and needed to be more methodical and patient.
On the ac/alt/tension pulley belt is there some way to "lock" it into position beyond the tensioner bolt facing the front of the car? It seems to be loosening a bit with the vibration of the motor.
Thanks, -m
Reply #3December 31, 2018, 08:11:22 pm
  • 1508
« Reply #3 on: December 31, 2018, 08:11:22 pm »
If it's like a 1.6, the sliding post for the idler has a 17mm nut to tighten to lock position that the tensioner adjusts.
S-PAutomotive.com
