VWDiesel Blog
Facebook Group
VWD on Twitter
Boost Hose
Topic: Boost Hose (Read 2060 times)
August 16, 2018, 10:03:58 pm
Frodo the Zuk
Newbie
Boost Hose
August 16, 2018, 10:03:58 pm »
I have a hole in my boost hose - the short elbow that connects the turbo to the intake. 1.6TD with T3. What is the best source or method for a replacement or repair?
August 17, 2018, 01:01:35 am
Moderator
Re: Boost Hose
August 17, 2018, 01:01:35 am »
This little hose?
http://www.mk1autohaus.com/Lifetime-Silicone-16L-TD-19L-Aaz-Turbo-Diesel--Intake-Boost-Hose_p_6518.html
Look to make sure it is for the T3 they have several different ones available.
August 17, 2018, 08:17:56 am
Frodo the Zuk
Newbie
Re: Boost Hose
August 17, 2018, 08:17:56 am »
That's the one, and that's pretty much the only source I found. I'm curious as to what others may be doing or about any other options.
August 17, 2018, 10:00:07 pm
Moderator
Re: Boost Hose
August 17, 2018, 10:00:07 pm »
Spendy, yes but it is THE ONE to get. You might have luck finding someone parting out an engine that would sell you the hose but the condition might be less than what you need. I decided if I was going to depend on the increased airflow into the metal parts I would cough up the coin for the new hoses. Nice Silicone from them too.
August 21, 2018, 07:59:26 am
Gizmoman
Re: Boost Hose
August 21, 2018, 07:59:26 am »
Go into your Friendly Local Auto Parts Store (FLAPS) and ask to browse through the radiator hose selection. Find one that closely matches your needs and cut to suit. You may need to use part of your old hose as an adapter ring to get to the proper size on the small end. Definitely use T-bolt clamps to insure it doesn't blow off. The only issue I can see with that is that the ID of the hose may not be compatible with oil (but my guess is it would be). Might also be worth going here as well
http://www.frozenboost.com/holset-turbocharger/
August 21, 2018, 12:02:58 pm
Frodo the Zuk
Newbie
Re: Boost Hose
August 21, 2018, 12:02:58 pm »
Clean wraps of high temp self-sealing silicon tape is working for now. Just sent my daughter off to college, so trying to hold onto my pennies.
August 21, 2018, 03:58:55 pm
Moderator
Re: Boost Hose
August 21, 2018, 03:58:55 pm »
So Sorry to read this statement:
especially in context of this one.
So, trying to hold onto my pennies.
Don't you know girls in college negates saving anything? Education of both students and parents. Best of luck for the next few years.
August 21, 2018, 05:34:16 pm
Re: Boost Hose
August 21, 2018, 05:34:16 pm »
You can probably measure the two connections and get an angled silicone coupler that will work for less $ than the stock hose.
My daughter starts college next week. She has a full tuition scholarship and will be living at home, though, so there is no financial crunch from it. I feel blessed.
August 22, 2018, 07:46:51 am
Frodo the Zuk
Newbie
Re: Boost Hose
August 22, 2018, 07:46:51 am »
My girl got the majority of her college covered, thank God! Still, pennies gotta be pinched! And, on top of that, I get a lot of satisfaction keeping my rig in top shape with just my wits and a prayer... fixing instead of replacing, you know?
Boost Hose
