Author Topic: Gas Tacho / Revcounter Conversion to Diesel W terminal  (Read 288261 times)
Reply #60March 03, 2009, 09:14:14 pm
westcoaster
« Reply #60 on: March 03, 2009, 09:14:14 pm »
I'll let you know how this works in my suzuki samurai....
It's real, it's cheap, and it's simple.
'87 suzuki samurai with a 1.9 AAZ TD transplant
Reply #61March 28, 2009, 02:25:12 am
BGA
  • 48
« Reply #61 on: March 28, 2009, 02:25:12 am »
Wonderful thread. I have nearly finished my mTDI AFN-based build. For monthts my brain has worked on the problem: how to use the nicely built in vw sensor. Biased more to mechanics than electronics I knew that filling two gaps on the sensorwheel with steel would do the job. Not nice work wih an assembled engine! I knew that a divider by two would do the jobb. This and a device to protect it from spikes is all I knew on the electronicall side of it, so now I look forward to Smokey Eddys solution. The vw sensor (G28) has three terminals.1 and 2 is the coil and I guess 3 is grounding the capsule. I connected 1 and 2 to a volvo/yazaki gasser tacho and tested it on my lathe and it showed correct and stabel rpm.
Bo Gunnar
Bo Gunnar
Reply #62March 31, 2009, 06:02:46 am
jimbote
  • 168
« Reply #62 on: March 31, 2009, 06:02:46 am »
Quote from: "BGA"
Bo Gunnar
Sweet!!!....cant wait to see the final result... :D
Reply #63March 31, 2009, 06:10:20 am
jimbote
  • 168
« Reply #63 on: March 31, 2009, 06:10:20 am »
still working perfectly!!!!
Reply #64June 01, 2009, 07:06:22 am
regcheeseman
  • 714
Re: Gas Tacho / Revcounter Conversion to Diesel W terminal
« Reply #64 on: June 01, 2009, 07:06:22 am »
so is mine!
 :P
I tried the 'latch' method as the first way to crack this problem. I believe the ratio using UK spec pulleys was close enough 1:10 - the rest could be dialled in with the cal pot.
I used a 'divide by 10' 4017 chip, circuit worked fine on the lab bench. However the W term was too noisy.
I could have used some signal processing on the front end and further signal conditioning on the output to get a decent 12v square wave out.
As for the auxillery pick up method  - it's not factory - adds engine bay clutter and wasn't the reason for this post. Might be nice to tap the bell housing and pickup on the flywheel. Could also work as TDC detection...
Reply #65June 02, 2009, 07:04:42 am
« Reply #65 on: June 02, 2009, 07:04:42 am »
Good to know!  I have a question- since you are using two nuts 180 degrees out on the crank, it would be feasible then if you were driving the tach with the intermediate shaft or camshaft pulley that you would use 4 "pickups" instead of two, since it turns at half the speed?
Reply #66June 06, 2009, 01:20:19 pm
jimbote
  • 168
« Reply #66 on: June 06, 2009, 01:20:19 pm »
Yes Brendan you would need four (4) "poles" for any shaft running half speed of the crank for and accurate tach signal....Jimmy
Reply #67August 02, 2009, 07:23:39 am
92EcoDiesel Jetta
« Reply #67 on: August 02, 2009, 07:23:39 am »
Hi jimbote, I just got  CE1 gasoline cluster with a tach which has a fuel gauge on the bottom. I will try to make it fit it my cluster which is a CE2. Looks like I have to custom wire the tach which has a 4 pin connector(only 3 pins used). Did you wire the tach to the voltage stabilizer or direct to 12V ?
Reply #68August 04, 2009, 12:40:26 pm
lusob
  • 9
« Reply #68 on: August 04, 2009, 12:40:26 pm »
Anybody have idea how to install tacho from golf 2 GTI with MFA to golf 2 diesel?
Reply #69September 04, 2009, 01:45:48 pm
Elwood
  • 3
« Reply #69 on: September 04, 2009, 01:45:48 pm »
Really? I can only see the last two of circuit boards. I imagine there should be a wiring diagram?
Reply #70September 05, 2009, 07:40:35 am
Elwood
  • 3
« Reply #70 on: September 05, 2009, 07:40:35 am »
what? why are you being indirect?
The original post talks about wiring, and has gaps in it where I believe images should be. I quote the post, and can see the image links for the missing images, but they do not load. Therefore, there should be more images in the original post, most likely wiring diagrams!
All I'm asking is for someone who has them load to rehost them on another website so I can wire up my speedo! Why are you being so difficult?
Reply #71September 15, 2009, 03:49:34 am
regcheeseman
  • 714
« Reply #71 on: September 15, 2009, 03:49:34 am »
Didn't realise they were missing, I'm guessing the IT fascists at my previous workplace have cleared the stash of files that I'd hidden on one of their servers  ;D
Send me your email address on PM and I'll send direct. I'm not in a position to rehost for a few days as my homehub has gone tats up. As soon as I do, I'll change the links in the original post
Reply #72September 16, 2009, 10:06:54 pm
clyde
  • 10
« Reply #72 on: September 16, 2009, 10:06:54 pm »
I'd like to see schematics of the VDO tach. Particularly if you have one for the GLI single-plug cluster with MFA. Years 1988 through 1992/
Seems a lot cleaner to change a few electronic parts on a circuit board than to make mods and fasten sensors IF the signal from the W terminal will drive a modified gas tach!
Reply #73September 17, 2009, 06:23:32 am
regcheeseman
  • 714
« Reply #73 on: September 17, 2009, 06:23:32 am »
No 'IF' about it - no body has bothered doing it for your mk2 set of clocks for the obvious reason that you can buy a mk2 with a diesel tacho (i.e. GL, GTD and GT models) why would you bother converting a set????
Reply #74September 17, 2009, 06:39:15 am
regcheeseman
  • 714
« Reply #74 on: September 17, 2009, 06:39:15 am »
Pics now back on - cannot find biobill.pcb which is an annoted view of westmoreland pcb with yellow highlighted tracks and component IDs.
Biobill can you help?
