GTD Injector O-ring
Topic: GTD Injector O-ring (Read 2129 times)
August 08, 2018, 03:25:33 am
J58
Newbie
GTD Injector O-ring
August 08, 2018, 03:25:33 am »
Hi all,
this might be a bit of a long shot...
My GTD has recently started spraying fuel from cylinder 1 injector, its definitely not coming from the union between the HP Pipe and the injector so my gut feeling is that the O-ring has finally given up the ghost.
Before I go pulling the injector out i thought I'd ask if anyone on here knows of anywhere that still sells/manufactures O-rings for GTD injectors. I've tried various different places including VW themselves (where I was basically laughed at
Thanks in advance, Jess
August 08, 2018, 07:27:43 am
Re: GTD Injector O-ring
August 08, 2018, 07:27:43 am »
There are not any o-rings anywhere in the high pressure side of the pump/injectors. No o-rings in the injectors or between the injectors and the head. No o-rings between the injectors and the metal lines. No o-rings between the metal lines and the delivery valves. No o-rings in the delivery valves or between the delivery valves and the distributor head.
August 08, 2018, 02:17:58 pm
Buji88
User+
August 08, 2018, 02:17:58 pm »
Did it crack or blow the return lines between injectors? I would imagine that would cause your issue.
August 08, 2018, 09:01:26 pm
August 08, 2018, 09:01:26 pm »
Snug it down.
Or take the time to loosen the nut and see if the metal pipe is sitting nicely in the injector,.. then tighten it down.
GTD Injector O-ring
