Author Topic: Oil gauge sender  (Read 2166 times)
April 17, 2006, 07:04:30 am
stewardc
Oil gauge sender
« on: April 17, 2006, 07:04:30 am »
I have this sender which runs the idiot light as well as the console oil pressure gauge. Can anyone tell me which connection is for which application and where this sender is situated on the engine (1983 1.6 Turbodiesel)
Reply #1April 17, 2006, 08:47:58 am
Baxter
Oil gauge sender
« Reply #1 on: April 17, 2006, 08:47:58 am »
G - Gauge.
WK - Warning light.
Remember the warning light is a normally closed type so if you have the "Buzzer of doom" system with 2 oil pressure switches this sender wants to go in place of the normally closed switch.
Easiest way to tell is the one with the blue wire is the normal one, the other one with the yellow wire is for the "buzzer of doom"
Reply #2April 17, 2006, 09:12:05 am
Baxter
Oil gauge sender
« Reply #2 on: April 17, 2006, 09:12:05 am »
You can see on the hex bit it says 0-5 bar so you need a 0-5 bar gauge.
Further 'round it will tell you what pressure the swtich contacts work at.
http://www.siemensvdo.com/products_solutions/special-oem-solutions/instrumentation/vdo-cockpit-vision/oil-pressure-gauge/oil-pressure-gauge.htm
