Author Topic: vanagon aaz oil quantity  (Read 2467 times)
May 18, 2018, 09:09:55 pm
mortisetortoise
  • 29
« on: May 18, 2018, 09:09:55 pm »
Is there a need for more oil in an aaz in the tilted vanagon orientation? When I fill the spec amount it is within range on the dipstick. However, there is a line scribed about 5mm above the stock hatched area. The swap was done by a PO and I don't know much about the conversion setup yet.
Reply #1May 21, 2018, 10:54:52 pm
zuhandenheit
  • 196
Re: vanagon aaz oil quantity
« Reply #1 on: May 21, 2018, 10:54:52 pm »
Are you using the vanagon dipstick (behind the license) or AAZ dipstick (side of motor). I didn't think the latter would work with the vanagaon diesel oil pan . . .
VW never put AAZ motors in vanagons, and so there's a little ambiguity re oil quantity. It will take a little more than a stock vanagon, on account of the turbo. 4.5 quarts should be right.
The stock vanagon diesel dipstick is not very accurate . . .
