S-PAutomotive.com
Author Topic: FS: AAZ single stage injectors SOLD  (Read 2156 times)
May 04, 2018, 02:10:01 pm
neimis
  • 75
« on: May 04, 2018, 02:10:01 pm »
Yes, these are original OEM AAZ single stage injectors. From my ’92 Passat AAZ Eco diesel (bought new off the dealer lot) these are the original injectors. I replaced them with two stage injectors and upgraded nozzles many years ago, so they have been sitting in a cupboard for almost ten years. Will need cleaning and balancing before installation.
More info:
checked my records and see that I removed them in Oct. of 2008, engine had 335,000 km. (208,000 miles). They have no damage, no leaks as I recall, and were working fine. I only removed them to install 2-stage injectors with upgraded nozzles. They have been sitting in a cupboard since then, and should probably be cleaned and balanced (or use the bodies for upgraded nozzles?). Overall length is 96 mm.
The stamping on the bodies:
Top line: KCA30S44 VW/Audi logos 068130202E
Bottom line: FRANCE 937 155bar
For what it’s worth, I didn’t notice any difference in noise or smoothness after installing the two stage injectors.
Do these also fit the 1.6 diesels? I don’t know, can someone confirm?
$40 US + actual shipping, I’m located in North Vancouver, BC.
SOLD
Neil
« Last Edit: May 12, 2018, 03:55:35 pm by neimis »
'92 Passat TD
'01 Golf TDI
'15 Golf TDI
