Author Topic: Do I need AAZ injector lines.....?  (Read 2586 times)
February 17, 2018, 06:15:09 am
ToddA1
  • 434
« on: February 17, 2018, 06:15:09 am »
Hey all, I have a running AAZ in my truck, but I’m running an A2 style IP, lines and injectors. Like many others, I’ve needed to tweak the lines to fit.
Would the short, single stage AAZ lines be a direct bolt on, or would I need to worry about delivery valves also?
-Todd
Reply #1February 17, 2018, 09:04:16 am
Re: Do I need AAZ injector lines.....?
« Reply #1 on: February 17, 2018, 09:04:16 am »
All the AAZ pumps had the long delivery valves.
Reply #2February 17, 2018, 04:45:00 pm
ToddA1
  • 434
« Reply #2 on: February 17, 2018, 04:45:00 pm »
Ok, so I have a set of long DVs.  Is it those and the short AAZ injector lines, all that’s required to make the proper connection to my A2 injectors?
Thanks for the reply.
-Todd
Reply #3February 17, 2018, 06:50:02 pm
« Reply #3 on: February 17, 2018, 06:50:02 pm »
Single stage AAZ injectors are dimensionally the same as 1.6 injectors.  With long delivery valves on any pump, the AAZ lines that fit the short injectors will fit without modification.
