Author Topic: Freshly built AAZ  (Read 3345 times)
October 10, 2017, 03:15:47 pm
RunninWild
  • 609
Freshly built AAZ
« on: October 10, 2017, 03:15:47 pm »
Think I've just about hit the final nail in the coffin on my samurai build. I'm just running into too many problems and I don't have the time or desire to fix the thing. I think its time to admit defeat and cut my losses
Specs are as follows:
Freshly rebuild AAZ block with maybe 100km on it since rebuild
1st oversized KS pistons
Arp head and main studs
Factory new AAZ head
Giles injection pump
He211w turbo with t25 manifold
G60 modified intake manifold
K&N Apollo intake (loud)
New glow plugs and timing belt and tensioner
Injectors could probably use a rebuild but it runs pretty well. Currently peaks at 27psi of boost and has tons of power. The block is painted ford blue the head and accessories are like an off black, the timing belt cover and the intake are bubble paint black and the valve cover is andonized blue. Its very clean, starts well and runs well but it smokes a bit which I'm thinking is due to the lack of mileage. Not sure what its worth I'm thinking like $3500? located in Langley BC.
