Author Topic: Bearing Contribution to Lower Oil Pressure??  (Read 5934 times)
August 25, 2017, 08:18:18 am
thomas m
  • 144
« on: August 25, 2017, 08:18:18 am »
If you cannot feel any free play in the big end rod bearing with your hand, does that necessarily
mean that the bearings are ok and not contributing  in a significant way to lower oil pressure??
If no free play in the rod bearings, does that imply that the main crank bearings are ok???
This engine has never been driven hard and has had the oil and filter changed every 3000 miles.
I was surprised at how clean the oil pan was having pulled it for the first time.
Comments, please.
Thomas, Original owner since new:
1991 MK2 Jetta Non-turbo 1.6 diesel, Engine Code ME, 5 speed 020 AWY 04120 transmission, Hydraulic Lifters,
320,000 miles
LOOKING FOR REBUILD OPTIONS IN PORTLAND, OR OR ON THE WEST COAST
Reply #1August 25, 2017, 12:27:56 pm
Re: Bearing Contribution to Lower Oil Pressure??
« Reply #1 on: August 25, 2017, 12:27:56 pm »
By the time there is enough play that you can feel it with your hand you'd have a pretty serious rod knock...
Bearings can be worn enough to cause low pressure without having slop. That said, if you are chasing an oil pressure problem I would start with the outer intermediate shaft bearing and go from there. They frequently get damaged due to overly tight timing belts.
Sent from my LG-H873 using Tapatalk
Reply #2August 25, 2017, 09:50:26 pm
Dakotakid
  • 1240
« Reply #2 on: August 25, 2017, 09:50:26 pm »
Tommie, read the first post....look at the pictures.
You have access to a lot of info if only you put forth the effort. Shortcuts will get you where you are going...rather quickly.
http://vwdiesel.net/forum/index.php/topic,34730.msg329063.html
Reply #3July 05, 2018, 09:01:51 pm
tcmoving
  • 1
    • bốc xếp hàng hóa
« Reply #3 on: July 05, 2018, 09:01:51 pm »
I can't go to this link -  can you check for me?
