Author Topic: 1.6 NA Head Options??  (Read 5695 times)
July 30, 2017, 12:43:09 pm
thomas m
  • 144
« on: July 30, 2017, 12:43:09 pm »
Outside of replacing the entire engine, what are the options for replacing the head on a 1991 1.6 NA????
Are there other heads that would fit??
Specs below.
Thomas, Original owner since new:
1991 MK2 Jetta Non-turbo 1.6 diesel, Engine Code ME, 5 speed 020 AWY 04120 transmission, Hydraulic Lifters,
320,000 miles
LOOKING FOR REBUILD OPTIONS IN PORTLAND, OR OR ON THE WEST COAST
Reply #1July 30, 2017, 04:30:53 pm
air-cooled or diesel
Re: 1.6 NA Head Options??
« Reply #1 on: July 30, 2017, 04:30:53 pm »
plenty of sources for a head, bare heads you should be able to find from $400, complete heads much more, if its not cheap.
Reply #2July 30, 2017, 07:09:20 pm
« Reply #2 on: July 30, 2017, 07:09:20 pm »
A TD head will fit fine too, doesn't need to be an NA one. Any hydraulic 1.6 diesel head will fit - '86 or so through 1992.
Sent from my LG-H873 using Tapatalk
Reply #3July 31, 2017, 05:33:49 pm
thomas m
  • 144
« Reply #3 on: July 31, 2017, 05:33:49 pm »
I'm going stock. Do you have any reliable sources in mind?
320,000 miles
Reply #4July 31, 2017, 06:22:24 pm
« Reply #4 on: July 31, 2017, 06:22:24 pm »
If you're fine with a used one posting here in the Classified section is probably your best bet. If you want new then Parts Place, VWDieselParts.com...
Reply #5August 08, 2017, 08:00:07 am
thomas m
  • 144
« Reply #5 on: August 08, 2017, 08:00:07 am »
The PartsPlace is just outside of Detroit. I'll be visiting there this summer and will take a look at their operation and maybe talk to their rebuilder.
320,000 miles
