Author Topic: AAZ mods question  (Read 2436 times)
July 28, 2017, 02:33:15 pm
jocefello
  • 2
AAZ mods question
« on: July 28, 2017, 02:33:15 pm »
445/5000
Hello
My name is Jose, I am from spain. I have a VW Vento/Jetta of the year 1993, with AAZ engine with the following modifications:
-IC Golf Mk3 TDI
-Boostpin
-Increase of turbo blowing
-pump up
I am thinking of changing turbo, mounting a conical air filter and putting a direct exhaust line.
Now the questions:
Are these modifications good for my engine?
What turbo do you advise me to ride?
Thank you
Excuse me for my English
Reply #1July 28, 2017, 05:25:40 pm
Re: AAZ mods question
« Reply #1 on: July 28, 2017, 05:25:40 pm »
The air filter won't help at all - the factory airbox already flows very well, more than the engine can ever use. If you are looking to make some improvements the snorkel on the airbox going in to the fender is a bit undersized, it can be replaced with a short piece of 3" pipe and a silicone elbow. It picks up fresh cold air from the fender, anything like a cone filter will just suck hot air from the engine bay.
The injection pump itself is where you'll find most power gains. Are you smoking at all currently? You can add an EGT gauge then turn the fuel up till it starts getting hot.
The stock turbo isn't too bad, it'll support 15-18 PSI without issue.
The intercooler you've added will definitely help.
Sent from my LG-H873 using Tapatalk
Reply #2September 13, 2017, 04:40:47 am
jocefello
  • 2
« Reply #2 on: September 13, 2017, 04:40:47 am »
Thanks friend  ;D
