Author Topic: Mechanical VNT control. Latest evo? Libbystyle?  (Read 7140 times)
May 22, 2017, 03:55:18 am
BGA
  • 48
« on: May 22, 2017, 03:55:18 am »
In another forum I put this question, but no replay.:
"Re: Mechanical VNT Turbo Vane Control
Post  by BGA » Thu May 18, 2017 7:37 am
Post by libbybapa » Fri Dec 14, 2012 10:16 am
Here are some design drawings of an updated design that eliminates the need for the spring in the linkage rod by always allowing the accelerator lever to return to idle regardless of vane position and boost can position".
Pics are in ( I think) : http://s13.photobucket.com/user/libbyba ... t=3&page=1
Does he mean pics with white background (can with tangential moving) or the ones with black background ( can with axial moving, often seen in other control systems, Libby, Rock3tman) ?
Has the "tangential moving can ever been built? Result?
I moved my question here in hope someone can give a hint.
Bo Gunnar
Reply #1May 22, 2017, 05:22:15 pm
Re: Mechanical VNT control. Latest evo? Libbystyle?
« Reply #1 on: May 22, 2017, 05:22:15 pm »
Yes, the tangential movement would eliminate the need for the spring in the rod.  Nope, never built it.
Reply #2May 23, 2017, 04:51:14 am
BGA
  • 48
« Reply #2 on: May 23, 2017, 04:51:14 am »
Thanks Libby!
I have made some remarks on your drawing. Are they okey?
My VNT lever works in oposite direction to your drawing so I have to swing the can around.
Bo Gunnar
Reply #3June 19, 2017, 04:03:23 pm
« Reply #3 on: June 19, 2017, 04:03:23 pm »
It would need some sort of guide bushing.
With a cable vs. solid linkage rod, what will push the vanes to the open position?
