Fuel filter location
Topic: Fuel filter location (Read 2792 times)
April 16, 2017, 10:04:49 am
Gator79
April 16, 2017, 10:04:49 am »
Does it matter if the fuel filter is above or belove the injection pump?
April 16, 2017, 12:03:48 pm
Moderator
4552
Re: Fuel filter location
April 16, 2017, 12:03:48 pm »
For most of the Rabbits and such that I have seen the filter is below the IP on the fender. Fuel is drawn up to the IP. Not sure about vans. I am unsure if you would have a problem mounting it above the IP. My question is where would you find the room to do that?
Last Edit: April 16, 2017, 12:05:53 pm by ORCoaster
April 16, 2017, 03:37:55 pm
April 16, 2017, 03:37:55 pm »
It'll be fine as long as it isn't TOO high above. If you're mounting it to the roof you might have issues.
April 17, 2017, 06:02:23 am
April 17, 2017, 06:02:23 am »
Doesn't matter much. Once the system is full, there is as much downward pull as upward pull.
April 17, 2017, 08:08:43 pm
Moderator
4552
April 17, 2017, 08:08:43 pm »
Have you any idea what the vacuum pull in on the inlet of the IP? I was thinking it was rather low like 3 lbs or so.
April 18, 2017, 05:03:03 am
April 18, 2017, 05:03:03 am »
IDK, but I rekon it's gonna be close to the resistance of the filter, plus the height above the tank (~20" h20, which is less than 1psi, if you want to measure in negative psi).
April 18, 2017, 08:32:04 am
kljaja
User+
April 18, 2017, 08:32:04 am »
I have it mounted next to downpipe on a firewall between downpipe and servo drum, as high as possible, works nicely
Going fast never killed anyone, suddenly becoming stationary, thats what gets ya
