Author Topic: KSB reduces power when hooked up  (Read 1950 times)
April 13, 2017, 03:22:50 pm
Jo3kr
  • 38
« on: April 13, 2017, 03:22:50 pm »
My new pump had a KSB on the front of it and cold starts were horrible so I researched this thing and decided to put switched 12v power to it.
It dramatically helped cold starts (before it would take 3 good tries to keep it idling on its own now it's run glowplugs crank it over and feather the throttle til the exciter kicks on the alternator)
But now I have poor performance I used to be able to spool the Holset turbo up to 20psi easily now I have yet to see it come anywhere close to 10-15psi.
Everywhere I've read says it should increase power and MPG.
Should I just put it on a toggle switch instead? Or is something a miss here.
Reply #1April 14, 2017, 11:53:38 am
Re: KSB reduces power when hooked up
« Reply #1 on: April 14, 2017, 11:53:38 am »
Can you post a photo of exactly what you have?
Some of those devices lock out the timing piston preventing it from adding advance as RPM increases.
