Author Topic: VW 1.6 NA to Turbo swap! Questions and Progress.  (Read 49368 times)
Reply #120July 04, 2017, 08:06:08 pm
Tmarkle
  • 153
Re: VW 1.6 NA to Turbo swap! Questions and Progress.
« Reply #120 on: July 04, 2017, 08:06:08 pm »
Well more great news! Injection pump is shot... when turning the motor over by hand the belt tries to walk off the pulley, and with the belt off the pump had a pretty good amount of play. This car is becoming addicted to my paychecks! Lol
1985 Jetta 1.6 NA, Project
1981 Rabbit 1.5 diesel SOLD
1980 Dasher, also a project
1993 Passat GLX VR6 (daily driver)
1992 Toyota Pickup, 350 V8 swapped
1997 Jetta TDI, engine donor for a diesel powered Toyota!
1986 Toyota Custom Cab
Reply #121July 05, 2017, 05:51:52 pm
air-cooled or diesel
« Reply #121 on: July 05, 2017, 05:51:52 pm »
dude, looking at prev pages & pics, i couldnt be sure, looks like you made one under estimation of your project. recent problems aside, which i hope you can get straightened out. what id like to point out and the question. is your exhaust one solid (&welded) piece to the turbo? that is a problem.
the factory old style (basic-hook up) the toilet bowl exh hook up, set up was an easy basic way to kind of 'separate' the exhaust. as one single piece the exhaust is now a solid extension, or lever of the whole engine. the old toilet bowl allowed a separation of the beginning of the exhaust and the rest -length of the exhaust. if its solid the whole exhaust is now a (solid) lever, where as you torque the engine the whole lever is dependent on the motor mounts, and you can ruin the exhaust and have all that torque going down to the muffler and tail pipe. on the 'newer' mk3's like ive kept up on and most newer cars as i take it, theres a separation (also) they will have a flex pipe, so the rest of the length of the exhaust (under the whole car) can just 'hang' there. the front part, the motor can now rotate, torque on the motor mounts.
Reply #122July 05, 2017, 05:55:14 pm
Tmarkle
  • 153
« Reply #122 on: July 05, 2017, 05:55:14 pm »
Going to run a flex joint after the down pipe so that nothing mentioned will cause a problem.
Reply #123July 05, 2017, 06:09:01 pm
« Reply #123 on: July 05, 2017, 06:09:01 pm »
hate to be a multiple critic; only trying to help. butt i thought id mention..
your intake being solid is quite the same. you need breaks, normally 2 are needed, the closest 2 to the motor. rubber hoses at the intake, (&clamps),any more are additional, like 2 on either side of the intercooler.  rubber can flex.
« Last Edit: July 05, 2017, 06:11:28 pm by air-cooled or diesel »
Reply #124July 05, 2017, 06:47:27 pm
Tmarkle
  • 153
« Reply #124 on: July 05, 2017, 06:47:27 pm »
Using a metal reinforced flexible radiator hose between the turbo and the blue charge pipe. Plenty of flex there lol
Reply #125July 06, 2017, 08:51:20 am
« Reply #125 on: July 06, 2017, 08:51:20 am »
thats one side of the intake, iirc, you installed an intercooler, so you have one line coming out of turbo, you say that one you have a rubber line on it, you now have a solid line to intercooler, in this case and on the other side on intercooler another flexible connection is real smart, then you will/should have another solid line back to intake(manifold) this needs a flex connection here. the next smart reason for flex rubber hose connection in all these spots is accessibility, you can now service most of that system just as easily as well.
Reply #126July 06, 2017, 09:21:36 am
Tmarkle
  • 153
« Reply #126 on: July 06, 2017, 09:21:36 am »
No intercooler, I know it looks like it drops down to a fmic but the easiest way to attach the charge pipe with how the K03 sits compared to the 1.8 intake manifold was to loop down and back. It will evening get an intercooler which is part of the reason I fabbed the charge pipe that way.
Reply #127July 07, 2017, 05:56:37 am
« Reply #127 on: July 07, 2017, 05:56:37 am »
so your good on the 'front side', its just the 'back side' there you need some help as i suggested, and gl with the other fixes, it usually is an investment. if you get it working right you may have a long time to enjoy it and tweek it.
Reply #128July 07, 2017, 08:59:43 am
« Reply #128 on: July 07, 2017, 08:59:43 am »
on the valve seal conversation, i just did mine, i just smothered mine in assembly lube and gently pushed them in the seals, so hopefully there was no damage, i didn't see any nicked pieces in the grooves or anywhere else.
Reply #129July 10, 2017, 08:49:48 pm
Tmarkle
  • 153
« Reply #129 on: July 10, 2017, 08:49:48 pm »
This is the TDC mark correct? Crank turned just a bit by accident with the belt off.
Reply #130July 10, 2017, 10:05:12 pm
« Reply #130 on: July 10, 2017, 10:05:12 pm »
That is what mine looks like except I painted it Red in the notch so I could see it better in low light conditions.
Reply #131July 10, 2017, 11:35:49 pm
« Reply #131 on: July 10, 2017, 11:35:49 pm »
Yes
Sent from my LG-H873 using Tapatalk
Reply #132July 17, 2017, 08:46:20 pm
Tmarkle
  • 153
« Reply #132 on: July 17, 2017, 08:46:20 pm »
So I'm probably in denial that the pump needs rebuilt or replaced, but is there anything else that could cause the belt to walk onto the lip of the IM shaft pulley? The IP shaft has some play but I would think that I would have had this problem the first time I had the belt off. The belt did loosen up after a however long between these repairs but I figured it was my substandard homemade tensioner tool or simply the tensioner being worn. Now that I think of it I may have forgotten the bolt that goes from the mini bracket to the back of the IP, would that cause this?
Reply #133July 17, 2017, 09:29:08 pm
« Reply #133 on: July 17, 2017, 09:29:08 pm »
You can adjust the belt tracking by adjusting the injection pump bracket.  I've described how about 8 gazillion times in the archives.  I'm too tired to type it again.
Reply #134July 17, 2017, 09:29:56 pm
Tmarkle
  • 153
« Reply #134 on: July 17, 2017, 09:29:56 pm »
Thanks, I'll take a look!
