Author Topic: 1.9TDi MLS head Gasket on a 1.6TD  (Read 3401 times)
March 21, 2017, 04:31:43 am
phaetonv10
  • 83
« on: March 21, 2017, 04:31:43 am »
Hi ALL
Posting on behalf of a friend.
he was replacing the cylinder Head Gasket on his 1.6TD, Engine Code MF, and ordered 1.9TD AAZ head gasket. part number 028103383BK.
but unfortunately, the HG he received was 028103383BQ, which is supposedly for the early 1.9TDi's.
the only visible difference is the reinforcement for the pre combustion chambers.
can we use 028103383BQ, 1.9TDi gasket  on the 1.6TD.
THE LEMON
1.6 GTD, FMIC, ARP Studs, Brembo brakes, Power Clutch, ibiza tdi twin fan setup, Racing Seats, 40 mm all aluminium radiator, audiophile music.
Reply #1March 21, 2017, 05:24:58 am
Re: 1.9TDi MLS head Gasket on a 1.6TD
« Reply #1 on: March 21, 2017, 05:24:58 am »
i wouldn't it will most likely leak around the prechamber with out that foil being there
Reply #2March 21, 2017, 01:29:27 pm
  • 2931
« Reply #2 on: March 21, 2017, 01:29:27 pm »
MF is a mechanical block isn't it?
Using a hydro head gasket can be tricky on a mech block.
Reply #3March 21, 2017, 02:04:37 pm
« Reply #3 on: March 21, 2017, 02:04:37 pm »
MF is typically a hydraulic engine.
The TDI gasket cannot be used, as mentioned it won't seal around the prechambers properly.
Reply #4March 22, 2017, 11:22:24 am
« Reply #4 on: March 22, 2017, 11:22:24 am »
I've had both MF blocks that were solid lifter and MF blocks that were hydraulic.  I've always found it fairly amusing that VW used the same block code for two non-interchangeable block designs.
